Plastic Inserts between leaf springs, 1960
Old Nov 6, 2004 | 09:24 PM
Monte Doenz's Avatar
Monte Doenz
Gentlemen,
Who makes the round plastic anti-squeek inserts that go between the leaf springs, about 2" in diameter with the center pushed out on one side. It fits into the ends where there is a pocket on the inside of the spring. For my 1960 Ford F-100 4x4.
Once again thanks for all your help.
Monte
Old Nov 6, 2004 | 10:54 PM
fatfenders's Avatar
fatfenders
Do you have a spring shop local? If not the F1/F100 stores sell them, for three times the price.
Old Nov 7, 2004 | 11:19 AM
imlowr2's Avatar
imlowr2
I've seen people make their own out of plastic. They work too. Check 4x4 stores also who do suspension work.
Old Nov 7, 2004 | 11:48 AM
sevenL4's Avatar
sevenL4
MONTE, I made my own using Delrin, a durable and machineable plastic. They must be working 'cause I'm not squeaking.
Old Nov 7, 2004 | 01:56 PM
StarFox's Avatar
StarFox
Delrin is good stuff, known as 'poor mans Teflon'. It is pretty durable too.
Old Nov 8, 2004 | 11:47 PM
51ford fan's Avatar
51ford fan
John's F-Fun Hundreds in Buena Park California Carries teflon in rolls that fit between the leaf springs. Just finished putting it on my 51 and it is working good so far. Best of all, it only costs $10.00 per roll, each roll does one axle.
Old Nov 22, 2004 | 09:14 PM
Monte Doenz
Gentlemen,
I found a company that sells the round plastic anti-squeek material for $1.00 a piece for 2" and 2-1/2" spring widths, they are called "Leaf Tip Inserts" in their catalog.
  • ESPO Springs 'n Things
  • 75 Pine Tree Road
  • Danville, PA 17821
  • (800) 903-9019
  • www.espo.com
  1. partnumber - D-41 for the 2" spring width..........round shape
  2. Partnumber - D-61 for the 2-1/2" spring width....hexagonal shape
Both with dimples in the center.
Regards,
Monte
Old Nov 23, 2004 | 06:15 PM
StarFox's Avatar
StarFox
Thanks Monte, I'll be looking at mine this winter I expect and I am sure I'll need to replace mine as well.
Old Nov 24, 2004 | 06:27 AM
ke6bnl's Avatar
ke6bnl
No Limit Engineeering sellls the flat material that goes the full length of each spring that is what I went with. Ed ke6bnl
Old Nov 24, 2004 | 08:02 AM
AXracer's Avatar
AXracer
That works well for flat spring leaves, the buttons work best for the springs with the depressions in the leaves. Whatever you use be sure to sand off any sharp edges or worn areas or you'll just tear up the new material in nothing flat.
montego69
56
Mar 31, 2015 12:57 PM
tenchustealthx
13
Sep 11, 2014 09:00 PM
prorad
May 1, 2013 01:22 PM
truckmonger1
Oct 25, 2009 07:30 PM
ralf
Jul 10, 2007 04:02 PM
