Truck - 2004 F 250 4x4
Motor - 5.4 gas
Gears - 4.88's (8 in lift with 37's)
My turck is supposed to be equiped with limited slip. The other day I was backing up a soft sand bank to hook up to a trailer and my passenger side rear wheel started to spin. I put the juice to it more to see if the limited slip would power up the other wheel also. It did not only burried the right rear wheel.
When I was getting my gears put in the mechanic showed me that the truck is equipped with it.
The operative word here is LIMITED. The big problem is that the tighter a limited slip clutch pack is, the more noise they make in tight turns at low speeds. People don't like their new cars and trucks to make noise. So the factory builds the packs loose and then to make matters worse they put a friction modifier in the lube to make the clutches slip even more. I'll bet if you jackup your truck you can turn the wheel by hand. Now if you can overcome that clutch pack, how much power do you think is getting to the ground?
If still under warranty ,your clutch pack is worn out. The replacement is fairly easy and ask to have the pack shimmed to the minimum for added bite and life. The only drawback will be occasional chatter in tight turns.Parts for the old 9" or the 8.8 are about $100 I expect a little higher for the larger sterling axle but probably not much.
I noticed that mine was doing the same thing so I drained the diff. and refilled with fluid and ford recomended additive and no more slipping. A lot quicker and cheaper than taking it somewhere to have new clutch pack put in. May want to try this first. Make sure you use the correct additive though. I got mine at the dealer.
You can help your limited slip to lock up by applying a little brake while giving it gas. The brake reduces the torque difference between the two axles to below the slipping torque. You can do it with either the e-brake or the service brake, either way works.
I Have A 2004 F250 Sd Crew Psd. My Factory Sticker Says It Has A "locking Differential". The Dealer Said This Is Better Than The Limited Slip. I Have Driven It Off Road, And Have Never Noticed One Tire Slipping. Whats The Difference?
a locking differential only allows a wheel to spin faster than the driven speed, it does not use clutches to distribute torque.
But, Do Both Wheels Apply Torgue To The Ground. I Have Seen Both Wheels Spin In Sand, And On The Asphalt. I Have Watch My Wife Spin The Tires On Our Street The Very Few Times I Let Her Drive My Truck.
i have bever heard of a factory locker either. ford used to use "trac-loc" for there LS option years ago(my '95 bronco had a 3.55 trac-loc rear diff) but its still the same type of LS they use now. my 2001 sd window sticker says 3.73 limited slip rear diff. maybe they went back to the "trac-loc" nomenclature on the newer trucks and thats what he is talking about...dono
I will try the fluid change first because I doubt there is any warranty left on it since I have placed 4.88's in the rear ends and lifted it up. It only has 12k mile on it though...
To the other poster the dealer was talking about a limited slip differental - that is the only way they came from the factroy other than open.
OOOPS THE SALESMAN SAID IT WAS A LOCKING DIFFENETIAL. I JUST PULLED MY WINDOW STICKER. IT IS A 3.73 "LIMITED SLIP". MY MISTAKE.
Socal ,hit the nail on the head.certain situations,also type of ground your on either tire can break loose it.if this happens apply the brake and they will both spin.I've seen and had the weight of the truck be shifted to one side of the truck ,where the opposite wheel will spin,then apply the brake slightly then both will spin to get me out of a snow bank while plowing.
If tires are a spinnin, that means more torque than the tire has traction for. Lockers deliver 100% torque to both wheels.
