Sponsored by: Real Truck
gauge pod
Old Nov 2, 2004 | 12:20 PM
Pirate16's Avatar
Pirate16
Thumbs up gauge pod
i was just wondering how many have added extra guages. i have been watching if i am using my drivers side handle and i do not so i am going to get rid of it and putting gauges. i was thinking the 3 gauge pod, with ammeter, maybe a real trans temp but i don't tow a lot so its not real important. so what have you guys put in and what type (electric or mechnaincal) and if i do the trans is it easy to put the sensor in? and what look looks good? thanks for the input.
Old Nov 2, 2004 | 01:38 PM
Bear Hunter's Avatar
Bear Hunter
I just run boost and pyro on a pillar pod. Grab handle is of no use to me either. If you do heavy towing a trans guage is good insurance.
Old Nov 2, 2004 | 01:46 PM
Bear Hunter
The other good thing about a pillar pod is you will have your eyes on it without taking them off the road.
Old Nov 3, 2004 | 10:31 PM
vmax's Avatar
vmax
I put a three gauge pod in place of the handle. Vac/boost, volt meter and air/fuel ratio. Air/fuel ratio gauge looks cool but is not very functional because of the way the O2 sensor and coputer work to control the injectors, always swinging from lean to rich and back.
Old Nov 4, 2004 | 02:34 PM
MTMike's Avatar
MTMike
I have ISSPro Boost, Tranny and Pyro, in that order from top to bottom. Tranny sits at the lowest reading most of the time, even when towing an 8k travel trailer. They are a must as I also use the Predator and it's <b>very</b> easy to get the pyro into the red. New Exhaust will be done in the spring.
mike in montana
Old Nov 4, 2004 | 02:44 PM
cwb's Avatar
cwb
I put two gauges on the dash on either side of the column. I just drilled it out with a 2" drill bit. Looks much better in my opinion. I had the pod and it looked like poo and blocked my vision. I drive fast. I need to see.
Old Nov 4, 2004 | 03:08 PM
FortyFords's Avatar
FortyFords
If you don't want to lose the handle or mess with the a-pillar .Chk out my setup in my gallery ,I like it works great and guages match the factory colors.
Rich
Old Nov 4, 2004 | 06:07 PM
jeepgod's Avatar
jeepgod
i use the handle.. and would like two guages to the truck.. but so far.. havent seen much that i like.. im not much into digital read outs.. was thinking of something to the sides of the steering column..
anyone do something like this... or put guages in without the pillar?
Old Nov 5, 2004 | 10:03 AM
cwb's Avatar
cwb
Look two posts up. I will get a pic.
Old Nov 7, 2004 | 07:48 AM
dsweger's Avatar
dsweger
I found that I didn't use the handle, so I installed 3 gauge A-Pillar pod. Used ISSPRO gauges and am pleased with the results. The setup gets a lot of Oohs and AAhhs from guys who haven't seen them before.
I have pictures in my gallery of the gauges both daytime and nighttime.
Good luck with whatever route you choose.
snakedoc
Aug 21, 2012 11:01 AM
nossliw
Mar 5, 2012 01:08 PM
DOC1KOC1
Jun 21, 2011 05:48 PM
Pirate16
Dec 12, 2004 11:02 AM
welder2000
Apr 9, 2004 12:09 PM
