Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Worst engine 302-why?
Old Feb 9, 2005 | 05:55 PM
  #106
F-Deuce50's Avatar
F-Deuce50
Some people are not as well educated with the 302 ci as other are. They tend to bash just because its a FORD.
Old Feb 25, 2005 | 08:35 PM
  #107
planckton's Avatar
planckton
The main problem with the 302 is that its way oversquare bore/stroke configuration and its poor volumetric efficiency (it can't breathe) renders it a dismal engine for towing anything heavier than a lawnmower. It was an okay car engine but a lackluster truck/towing engine. They perform horribly below around 2500 rpm and even when they're wound up they don't exactly light the world on fire. On top of that their fuel economy is poor for no more power than they make. The only thing a 302 has going for it in a truck application is its reliability/longevity. Despite being slugs they do tend to last a long time and not give much trouble.
Old Feb 25, 2005 | 08:54 PM
  #108
planckton's Avatar
planckton
Originally Posted by t_dickie
A stock 302 will not touch 6000rpm
They'll do the 6000 rpms but there's really no point in turning a stocker that high. The top end of the motor breathes so poorly that it's all bark and no bite. It's only making a fraction of its peak power at that rpm.
Old Feb 28, 2005 | 08:43 AM
  #109
termyt00's Avatar
termyt00
Your right Planc, most people don't figure out that the stock ford heads are the biggest restriction in these engines! they are done this way to produce LOW torque...and pass emmissions. even the early '60's heads were really sorry. they were designed for 260ci and 289ci engines. One of the main reason's Ford used cleveland heads on the BOSS 302 and they wanted to win... So if you really want to build a screeming 302/ 351 you'll have to go to a set of aftermarket heads...WORLD, AFR, CANFIELD, TRICK FLOW, EDELBROCK, FORD GT-40...Just to name a few. i recently installed a set of WORLD W.Sr. on my 427 and what a difference ...
Old Feb 28, 2005 | 09:16 AM
  #110
GreekGod's Avatar
GreekGod
Say what you will about the poor flowing heads on 289's & 302's, they flowed good enough for 289 Mustangs to whip the BEST GM had in SCCA racing: the 327 CORVETTE! So much for "sorry" restricted design.
Old Feb 28, 2005 | 09:45 AM
  #111
GreekGod's Avatar
GreekGod
FE "BOAT ANCHORS"
I Believe 428 Mustangs w/boat anchor FE's still hold national NHRA records in B/SA or similar classes of drag racing. The 428 is a quicker revving engine than the [canted valve] 429, possibly because of a lighter crankshaft and ports that make more torque [fact. stock].
Originally Posted by DOHCmarauder
Good post. Confused on your "siamesed block" statement. Never have seen ANY Ford regular production block that didn't have full water jackets.(there is an SVO BLOCK that's siamesed)
Gotta chuckle at the "289 is better than 302 statements" from other posters. The most comical was the "old school 255" comment. Considering the 255 was conceived AFTER the 221/260/289/302.
I do love old timers reliving the glory years. The FE in 427 guise (especially SOHC) were forces to be reckoned with. But all other FE's became boat anchors when canted valve heads(ford/chevy) on big blocks became the norm.
4 bolt boss blocks(rare) and even thin wall castings with a cheap girdle will spin easily and reliably to 7k.
The small block chevy and 5.0(actually 4.9) Ford are easily the most aftermarket supported engines of all times.
Old Feb 28, 2005 | 11:35 AM
  #112
Silver Streak's Avatar
Silver Streak
I've never had any real problems with any SBF. They are well know for head gasket issues when performance is increased significantly over stock. This is because of the low number of head bolts. They are also known for twisting off oil pump driveshafts. Other than that I don't know of any issues. Some people hold external balancing against them as well, but that really isn't a reliability issue.
Old Feb 28, 2005 | 03:59 PM
  #113
ddogg126's Avatar
ddogg126
I have a 76 F-100 short box 1/2 ton it has a 302 with a 3 on the tree and it still run strong. It get's pretty decent gas mileage on the highway. Only problem i've had was my A.I.R. pump going out. But it was the original only about 29 years of work and quite a few miles put on it.
Old Feb 28, 2005 | 11:35 PM
  #114
DOHCmarauder's Avatar
DOHCmarauder
The reason that the 428 does well in stock classes is that they are artificially underrated (335 HP)and actually hold a weight advantage over a lot of rivals.
Also, besides the ultra rare Boss 429, the 429's weren't available until the supersize '71.
I love FE's. GREAT historical motor. Except for the SOHC motor it does not have as much potential as a 385 motor........Sorry.
Old Feb 28, 2005 | 11:47 PM
  #115
fordbeast_80's Avatar
fordbeast_80
FE's are not historical they kick stuff too this day.
Old Mar 1, 2005 | 01:26 AM
  #116
DOHCmarauder
Yup, and the flathead Ford beats 'em all.
Old Mar 1, 2005 | 06:10 AM
  #117
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
What 385 do you speak of?
Old Mar 1, 2005 | 08:03 AM
  #118
Momudder720's Avatar
Momudder720
How big can you bore and stroke out an FE? I know you can get 700+ ci out of a 460 block. If Bigfoot used an FE, I probably would too. Buttedon't.
Old Mar 1, 2005 | 12:49 PM
  #119
DOHCmarauder
Sorry for the confusion.
I should of said, "385 series of engines" which includes the 429/460.
Old Mar 1, 2005 | 03:02 PM
  #120
Silver Streak
Those cars don't hold those records because the 428 was such an awesome engine, they hold the records because the 428 Mustangs had the best power to weight ratio of any car available. By the time the 429 came around the cars had gained several hundred pounds. I find it pretty hard to believe that a 3.98" stroke 428 will rev more quickly than a 3.59" stroke 429, and it certainly doesn't have the power potential of a 429 or 460. Power is ultimately limited by valve size, which is ultimately limited by bore size. You can't stuff nearly the valve in a 4.13" bore as you can a 4.36" bore, especially when the valves in the 4.36" bore are canted. You can't get away from the fact that the 428 was derived from an engine family designed for grampa's Edsel and trucks, while the 429 was designed for performance.
