excursion vibration ?
Old Nov 5, 2004 | 02:21 PM
chrisksnell's Avatar
chrisksnell
Cool excursion vibration ?
My 03 Excursion Diesel 2X4 has been in the shop 6 or 7 times for vehicle vibration, steering wheel, floor board and seats vibrate. I've exhausted recourses at ford so now I'm off to Pirelli ?
Has anybody had this problem ?
Old Nov 6, 2004 | 08:53 AM
Oilman03's Avatar
Oilman03
Vibration
Did they check the u-joints?
Had same problem with mying several times. Have replaced mying four times now.
Old Nov 7, 2004 | 06:52 AM
docgreen's Avatar
docgreen
Chris.... welcome and join the club. My 03 has been into the shop now 5 times for a total of 45 days for the same vibration you describe. It's on it's 3rd rear end, second drive shaft, and they just put a new trans extension housing on it. Nothing is solving it. We are going through buy back now on this one and hopefully getting a new one. Mine is definately a driveline vibration and not tires. Seems to me to be a 2wd diesel truck issue. I've driven 3 4x4 diesels and none of them have a single vibration. I drove a new 05 2wd and it does the same thing as mine. If we get a new one I might have to order a 4x4. Good luck on your trouble.
Old Nov 9, 2004 | 11:49 AM
romulin's Avatar
romulin
Gentleman, welcome to the club. I have had this problem and I was able to make it 80% better. My 2003 Excursion was also in the shop multiple times, received a new rear end, 3 new driveshafts, new U-Joints. Then the dealer changed the angle of the rear-end by inserting 4 degree shims under the leaf springs. This took all my vibrations out except for a liveable vibration at 80 to 90 MPH. I personally think it should have been 3 degree shims but anyway it worked.
Brian
Old Nov 9, 2004 | 03:55 PM
docgreen's Avatar
docgreen
Brian thanks for the info. I might be able to use that info to get mine changed to 4 deg.
noimports
Apr 22, 2018 09:08 AM
Dhudec
Feb 2, 2018 09:13 AM
johnsonjf
Apr 6, 2017 09:39 PM
srauner
Jul 2, 2016 12:44 PM
Jco06
2009 - 2014 F150
18
Jun 12, 2016 10:15 AM
