Sponsored by: Auxito
digital odometer not light up
Old Nov 5, 2004 | 02:14 PM
newt sweet's Avatar
newt sweet
i have a 99' f-150, sometimes the digital odometer wont light up when i start the truck. does anybody have any clues as to ehat is happening?
Old Nov 5, 2004 | 03:40 PM
gwhoekstra's Avatar
gwhoekstra
Try this link https://www.ford-trucks.com/forums/a...x.php/t-196821
Old Nov 5, 2004 | 03:48 PM
Switch's Avatar
Switch
I looked through a Haynes manual to see if I could locate any relays or fuses that may have popped but I couldnt find anything about the digital odometer.
Does the instrument cluster light up at night?
JB
Old Nov 5, 2004 | 03:53 PM
Switch's Avatar
Switch
^^^As far as his reply goes, make sure to "...disable the airbag system before working in the vicinity of the impact sensors, steering column or instrument panel. Failure to follow these procedures may cause accidental deployment of the airbag...The airbag circuits are easily identified by yellow insulation covering the entire wiring harness. Do not use electrical test equipment on any of these wires or tamper with them in any way. -Haynes"
JB
Old Nov 7, 2004 | 02:46 PM
newt sweet's Avatar
newt sweet
digital odometer not lighting
hey, thanks for the link and all the help. i tore my dash apart today and resoldered the point the picture shown. hope it works, it is working now but it was mostly interment, only happened a few times. only time will tell if i actually fixed it or not. again thanks. it wasnt so hard to do afterall.
Old Nov 7, 2004 | 03:12 PM
newt sweet's Avatar
newt sweet
i was just thinking, after putting the dash back together, i should have asked if any body had any idea as to what wire to cut, if possible, to be able to have the driving lights on when the bright lights are on. seems it would be an easy fix if some body could me it is possible.
BrianFX4
2004 - 2008 F150
Jul 10, 2008 09:21 PM
technomon
Sep 29, 2007 07:46 PM
93PGT
1997 - 2003 F150
Jul 19, 2006 07:28 PM
jayrak
Apr 30, 2004 01:39 AM
jayrak
Feb 21, 2004 11:33 PM
