Oil & Lubrication
Motorcraft Oil
Old Nov 4, 2004 | 01:49 PM
Ned Nimrod's Avatar
Ned Nimrod
Motorcraft Oil
Today when I changed oil I looked on the back of the 5w-20 Motorcraft oil container and I noticed that the oil meets Ford's WWS MC2930A specs. Also it is for service SM.
Is this an upgrade? Is this better oil than M2C153-H? Will it work in my '03 Screw?
Thanks,
Ned
Old Nov 4, 2004 | 03:36 PM
whimsey's Avatar
whimsey
Yep, it's the new upgraded oil. Use it in good health . And yes it's great for your 2003 S'crew or any vehicle that was originally spec'd for WSS-M2C153-H, 5W-20 oil.
Whimsey
Old Nov 4, 2004 | 04:04 PM
BrianA's Avatar
BrianA
Howdy Ned,
I can speak to the specifics of the 5w20, but a brief comment about my experience with Motorcaft oil.
I use their 10w30 in my 2000 w/ 4.2.
My UOA returned great numbers after about 5,000 miles of use.
I am a big fan of their oil and use it exclusively now (used ot use Chevron Supreme until Wally World stopped carrying it).
Old Nov 4, 2004 | 04:55 PM
Indybroncoman's Avatar
Indybroncoman
Ditto, I am a huge fan of Motorcraft 5w20. I even use it in my wife's Acura Integra.
Old Nov 4, 2004 | 07:47 PM
02PSD4ME's Avatar
02PSD4ME
I use it in my wifes 03 5.4L Expy, No problems.
I would also use the Motorcraft 15w40 in my powerstroke, but it only comes in QTs, and IM not going to stand there and pour 15 QTs in. So untill I can redily get it in Gal. Ill stick to the Rotella-T in Gal. jugs
Old Nov 4, 2004 | 09:49 PM
b2_tim's Avatar
b2_tim
My wifes Chevy even likes the Motorcraft 10W30. And at the last change for winter I put the new syn 5W30 in it. The bow tie has never been happier ( I also use it in my Ford trucks), and my Bronco II is running better with less leaks using Motorcraft 10W30 than with Castrol 10W30.
Old Nov 5, 2004 | 05:44 AM
DOHC's Avatar
DOHC
[QUOTE=02PSD4ME
I would also use the Motorcraft 15w40 in my powerstroke, but it only comes in QTs, and IM not going to stand there and pour 15 QTs in. So untill I can redily get it in Gal. Ill stick to the Rotella-T in Gal. jugs[/QUOTE]
It also comes in 5 quart jugs ..... yep ,yep it does
Geeze , no time to pour pour oil ? Sounds odd but to each his own
Old Nov 5, 2004 | 07:52 AM
TallPaul's Avatar
TallPaul
Pouring the oil in is the best part of the change, that and the smell of the used oil. But 15 qts definitely could be tedious. I have not cared for the 5 qt jugs of Valvoline because I have to use a funnel and I don't like the foil seal (always think a tiny bit is going to drop into the oil and destroy the engine). But some of the other 4 and 5 qt jugs have the smaller neck that could fit right in the fille tube--nice.
Old Nov 5, 2004 | 08:21 AM
02PSD4ME's Avatar
02PSD4ME
Originally Posted by DOHC
=02PSD4ME
I would also use the Motorcraft 15w40 in my powerstroke, but it only comes in QTs, and IM not going to stand there and pour 15 QTs in. So until I can readily get it in Gal. Ill stick to the Rotella-T in Gal. jugs
Yes 15 separate qts is a pain. 4 gals is much easier.
Also it is very difficult to carry 15 qts, but 4 gals I can do.
I don't need NO Stinking cart...
I have not seen it (motorcraft 15w40) readily available in gal in my area, not saying they do not offer it, but not in my area.
Old Nov 5, 2004 | 08:51 AM
DOHC's Avatar
DOHC
It comes in 5 quart jugs , not 4 quart .
Use those old Rotella jugs and pour two quarts of the Motorcraft at a time into them .
There's room
Old Nov 5, 2004 | 09:00 AM
02PSD4ME's Avatar
02PSD4ME
There's room
Not in my area it doesn't (5qt jugs) it is qt only
Old Nov 13, 2004 | 11:58 PM
ford390gashog's Avatar
ford390gashog
here it comes in 5 qt wally world sells them for 6.50 so you save money
Old Nov 14, 2004 | 06:17 PM
Brons2's Avatar
Brons2
Originally Posted by BrianA
Howdy Ned,
I concur about the Chevron 10w-30. I got 4ppm iron and 0 ppm lead in a 4980 mile interval on a 2000 4.2 using that oil and a Wix 51516. I tried to buy some for my new Titan and noticed that WalMart was no longer carrying it as well. So I went to O'Reilley's and bought 7 quarts at $1.39 per. I may use the Motorcraft 10w-30 in the future though as it has a nice add pack and is a Group II/III blend. Plus I can go to WalMart and buy it at 2am if I want .
What kind of analysis results have you gotten in your 4.2 with the MC 10w-30?
Old Nov 14, 2004 | 06:52 PM
Golfmore's Avatar
Golfmore
I've been using it in the 97 Volvo 850 Turbo for the last two changes. I'l stick with it.
wildcatracer
Feb 26, 2013 05:18 PM
99rangerdan
Apr 3, 2011 08:18 AM
Nedcampion
1947 and Older Ford Trucks
32
Dec 16, 2009 06:34 AM
Ned Nimrod
1997 - 2003 F150
Sep 26, 2007 01:35 PM
Ned Nimrod
1997 - 2003 F150
15
Jan 10, 2007 01:09 PM
