Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Drywall Tape
Old Nov 15, 2004 | 04:02 PM
  #31
Big Orn's Avatar
Big Orn
Originally Posted by Bigham
I have never had that happen. Is it a new wall? Maybe it is setteling. Certianly another coat would take care of it.
Ed
Yes, a new wall. And it's just alligator cracking, not stress cracking. I was hoping that it would not interfere with the last coat.
You can see that it's not deep, but very visible.
Old Nov 15, 2004 | 04:11 PM
  #32
Aftrmidnite's Avatar
Aftrmidnite
At work the rooms that had extreme temperature shifts we had a dry wall guy who used metal window screen cut into strips for the joints.
Old Nov 15, 2004 | 04:22 PM
  #33
Big Orn's Avatar
Big Orn
I can understand that - for stress cracking - but this is just surface cracks.
As physics go (and that's all I can use since I'm not skilled at this) it seems that the paper allows the mud to dry much slower than the mesh does.
Also I think I might be trying to put too much mud on at once, but I just don't know enough about it to know for sure. I don't think it's a problem and a drywall man might just shrug it off.
Old Nov 15, 2004 | 04:35 PM
  #34
Bigham's Avatar
Bigham
Did you use a lot of spackle? If you put it on to thick it will crack when it is drying.
Old Nov 15, 2004 | 04:37 PM
  #35
Aftrmidnite
Mud was old, over or under mixed, applied it at the wrong temperature, or someone had let it dry out, left the lid off, and they thinned it too much.
Old Nov 15, 2004 | 04:39 PM
  #36
Big Orn's Avatar
Big Orn
No. I used the premix stuff in the 5 gal buckets.
I think that may be it.
Old Nov 15, 2004 | 04:45 PM
  #37
Big Orn's Avatar
Big Orn
Mud was old
I did notice that this batch was a little harder to smooth out than the last batch. It could have been old. How do you know if it's in the 5 gal buckets of premix?
over or under mixed
Premixed
66 degrees F and higher. What range should it be applied? Over that?
Nope. Kept the lid tight at all times...and I have no one to blame but me for any of this.
FYI - I talked to the guy that's supposed to be doing this today. He made up excuses for 10 minutes. Gonna look for someone else...unless I get through with it myself beforehand...
Old Nov 15, 2004 | 06:25 PM
  #38
baitmaster's Avatar
baitmaster
bead crimpers
Yrs ago the metal bead crimper came out, and instead of nailing bead on we just crimped it, and started with the mud. Well, after having to go back to a house where the kids knocked the bead off the corner with their Big Wheel, we went nailing them on after a few hits with the crimper just to hold it on til we nailed it.
Old Nov 15, 2004 | 06:30 PM
  #39
baitmaster's Avatar
baitmaster
Surface cracks usually come from mud that is too thin. Here's a good one: One time I got a call from a bar owner that needed his newly rocked ceiling finished. He told me he already had it taped, just need some finish coats and paint. When I got there, I looked up, he had the joints taped alright... Duct tape. He left, I pulled the tape off and started from scratch, never told him.
Old Nov 15, 2004 | 06:45 PM
  #40
Aftrmidnite
When you get dry wall mud in the 5 gallon buckets you have to stir it before using. They have hand paddles and ones that go on a big half inch drill, and I do mean a big drill, as my half inch hammer drill won't even move in a bucket of mud.
Old Nov 16, 2004 | 06:30 AM
  #41
Big Orn's Avatar
Big Orn
I wonder why they don't write that on the stinking bucket!
I have gone through 5 1/2 buckets already!
Old Nov 16, 2004 | 04:35 PM
  #42
Bigham's Avatar
Bigham
The water seperates form the mud. I was also told that if you mix some liquid dish detergent into it it will go on smother for a final coat. It seemed to work for me.
Eddie
Old Nov 17, 2004 | 06:41 AM
  #43
Big Orn's Avatar
Big Orn
Eddie
Thanks, Eddie, I'll give that tip a try.
I looked over those buckets last night and through USG's web page and they didn't say a thing about needing to re-mix the mud...but that's another reason I came here: Lot's of good info.
As many tips and tricks as there are here on various things from digging ditches to installing fibe optic cable, DIY would do well to stop by now and then.
Old Nov 18, 2004 | 07:34 AM
  #44
Big Orn's Avatar
Big Orn
Bigham,
That tip worked great - went on as smooth as silk.
How far are you from New Boston, Texas....
Old Nov 18, 2004 | 05:07 PM
  #45
Bigham's Avatar
Bigham
Talking
Up in central New Jersey. You want me to come down so you can buy me a beer for the tip?
I'm glad it went well for you.
Eddie
