Hello All,
I would like to change my stock tire & wheel combo on my '04 F250 SD
to a 33 12.50 tire on 16x8 wheels.
Would I have any problems doing this? (other than speedo calibration)
The combo I'm thinking of is a set of superswamper trxus on
mickey thompson classic wheels.
thanks for any info.
Bear
For a 12.50" wide tire, 10" wide wheels may be a better choice. Just get 4.5" backspacing. Check out the posts under "Wanting bigger wheels". Chuck641 has pics of his truck with 35" tires and no lift although he did move his front bumper forward 1". With your 33" tires, you probably won't need to do that.
10 inch wheels Hmmm. Have to look into that option as that opens up a lot more
choices.
Im looking at the TrxUs STS radials a friend has the MT's and he likes them
but I like the look of the STS
Bear
Interco recommends an 8.5 to 10 inch wide rim for either the Trxus MT or STS in a 33 x 12.50 size. I found that a 33 inch tire brought my speedo to a correct speed when I compared it using either a GPS or mile markers. I had no clearance issues, but I have a F-350 with plow package and AR Baja 16 x 10 wheels.
I ordered the tires and 16x10 wheels, should have them early next week
My 250 also has the plow package so it looks like everything will be okay.
I'll let you all know how things go.
Thanks for your help.
Bear
I should clarify that I do not wheel my truck as some people have posted rubbing issues with a 33 x 12.50 tire while off-roading. I have a Range Rover as my wheeler so that I don't have to mess with taking off my plow frame and giving my nice SD trail pin-striping.
