engine swapping
Old Nov 2, 2004 | 10:46 PM
needfordknowhow's Avatar
needfordknowhow
Question engine swapping
Hi, everyone. I've worked on autos for years, but I always like to make sure of mods before starting them. I need help, I picked up a 1990 Ford 4wd with a 302 and a 5 spd. The engine has been getting weak, I'd like to put a used one in from a 84 marquis that i've got. Is this possible? If so, will the intake fit on the heads, the exhaust manifolds-will they fit on the older 302? And what about the flywheel and pilot? Are fords like chev. and they use removeable brass bushings? I would greatly appreciate any and all info. It's about ready to snow and get here in NoDak and I'd rather be ready.
Thanks again,
Nick
Old Nov 2, 2004 | 10:49 PM
scottie2hottie's Avatar
scottie2hottie
yes EFI manifold will fit old heads, and same for exhaust manifolds. Not 100% sure on clutch setup though. If all else fails, I do have a strong running 302 Im getting ready to put on the market if you're in OH.
Scott
Old Nov 3, 2004 | 08:37 AM
312's Avatar
312
same flywheel.everything should work.
Old Nov 3, 2004 | 10:10 AM
needfordknowhow
scottie, thanks for the info. what would you want for that 302, stock or modified?
I'd have to get it shipped, I'm in North Dakota.
Old Nov 3, 2004 | 10:16 AM
needfordknowhow
312, thank you also. But you didn't mention anything about pilot bearing/bushing. These aren't part of the flywheel on ford after a certain year, are they? I've seen a couple that way, maybe just some diesels are? Thanks again, the hookups to the heads were my main worries!!!
Old Nov 3, 2004 | 05:39 PM
scottie2hottie
Not 100% sure on what all I'm gonna throw in with it yet, so not sure on price. Won't be much, it's stock and has about 75,000 miles on it. It leaks a little oil out the valve covers, but that isn't a big deal. I'm gonna look at it later in the week to see what all works on my '76(alt. & brackets & stuff like that). Only thing is I'm sure shipping to ND would be quite a bit, never shipped anything like this b4 but I'm sure it's costly.
Scott
Old Nov 3, 2004 | 05:59 PM
312's Avatar
312
the pilot bearing is not part of crank.
Old Nov 3, 2004 | 07:48 PM
needfordknowhow
312, yea, they just sit in the end, and are removeable. But are they brass or bearing type on the fords after a certain year? I was told that the older fords either were or weren't cut to accept a bushing in the flywheel end of the crank. I just want all the bases covered. As far as being cut for bushings, I mean if was having a auto or a stick behind it.
