Offroad & 4x4
1994 Bronco Steering column
Old Nov 2, 2004 | 04:13 PM
denuch's Avatar
denuch
Help!!! I have a problem with my 1994 Bronco steering column. None of the controls on the wheel work. No horn or cruise control, and I have a flashing light for the air bag. It is driving me nuts... anyone have an idea what I in for?
Thanks,
Dennis
Old Nov 2, 2004 | 04:32 PM
fishmanndotcom's Avatar
fishmanndotcom
tried any fuses?
also, look under the dash on the colum itself and there should be a plug where if you need to remove the steering column you can unplug all the wires that lead to the electric controls. check that plug and make sure it is tight
-cutts-
Old Nov 3, 2004 | 12:58 AM
94Bronco58's Avatar
94Bronco58
Try throwin a line in the Full Size Bronco forum, I guarantee better luck in there!
Old Dec 15, 2004 | 04:45 PM
svtgtcobra's Avatar
svtgtcobra
yeh, that same exact thing happened to me, i just picked up my truck about 20 minutes ago, 1994 Ford Bronco XLT...and its the rotator cuff or sum thing, it defects...you have to get a new one, they have to take apart ur whole steering column, and airbag, and then put it all back together, my mechanic who i dealt with my whole life calls it (SNIP) to do, but he said he could, and he did...about a days work...so there you have it...good luck
Old Dec 15, 2004 | 05:05 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Originally Posted by svtgtcobra
yeh, that same exact thing happened to me, i just picked up my truck about 20 minutes ago, 1994 Ford Bronco XLT...and its the rotator cuff or sum thing, it defects...you have to get a new one, they have to take apart ur whole steering column, and airbag, and then put it all back together, my mechanic who i dealt with my whole life calls it (SNIP), but he said he could, and he did...about a days work...so there you have it...good luck
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Enjoy FTE
workingdog
31
Oct 10, 2016 02:21 PM
sammy78
1978 - 1996 Big Bronco
Jan 28, 2013 07:44 PM
mamelukesword
13
Jan 20, 2007 04:05 PM
RanchRodsTX
Jun 12, 2006 10:19 PM
original67
Dec 21, 2003 05:23 PM
