Rough idle on cold starts
Old Nov 1, 2004 | 09:02 PM
WPeoples's Avatar
WPeoples
Recently my 99 Expedition 4.6 L has been idleling erratically on cold starts, often cutting out unless given gas until the engine warms up. Once the engine is warm it runs fine. No trouble codes detected at Autozone (checked it two days in a row). The pcv valve is working fine and I checked all the vacuum lines. It has 70K and is due a tune-up, so I plan on replacing the plugs. Thinking about IAC valve.....Any suggestions?
Thanks
Old Nov 2, 2004 | 10:33 AM
buzzard's Avatar
buzzard
Definitely the IAC valve.
Old Nov 2, 2004 | 08:08 PM
WPeoples's Avatar
WPeoples
I thought it might be, so I went ahead and replaced it. I could tell the old one was worn on the inside. Seems to be working fine now. I am just a little disappointed that the PCM decided it wasn't worthy of a trouble code.
thanks to all who respond to questions...it sure beats going into these problems blindly
Old Nov 5, 2004 | 01:41 PM
Bedasi's Avatar
Bedasi
IAC Location???
Anyone have a picture of where the IAC is to replace?
Thanks all...
Old Nov 5, 2004 | 01:49 PM
buzzard's Avatar
buzzard
Bedasi, it's located on the top of the engine directly behind the throttle body kinda toward the passenger side. It is a small cylinder shaped part probably about 4-5 inches long with a couple wires attached to it.
Old Nov 5, 2004 | 09:21 PM
Bedasi's Avatar
Bedasi
Talking Thanks!
Thanks....now just think good thoughts as I'm going to see if I can fix it tomorrow!
Old Nov 5, 2004 | 10:02 PM
Phil056's Avatar
Phil056
Here is a picture of what it looks like. You can thank Monsta for this one! It has been posted previously. It is basically in between the firewall and the throttle body. Good luck
1'stonraceday
Dec 26, 2012 10:12 PM
terriblet63
Dec 15, 2009 04:51 PM
cowboy51
Nov 8, 2006 12:07 PM
srbz
Jun 5, 2006 01:08 AM
Joe Mac
Mar 16, 2003 11:26 AM
