Using Scandisk
Old Nov 1, 2004 | 07:17 PM
Mil1ion's Avatar
Mil1ion
Using Scandisk
I have a problem with the DIR files on my hard drive.
Scandisk would only get to 9 % of the files. (Not enough memory to complete)
So, I shut down the computer with the start-up disc for 98SE in A drive in order to have it do the scan the H/D.
Well after manually clicking the enter button on *Fix it* over a 1500 times,It can stll only scan 29% of the files (ISTMP dir) files.
Is there another way for the fixin to take place besides me tapping the enter button to fix each & every file one at a time ?
Old Nov 1, 2004 | 07:44 PM
flyboy2610's Avatar
flyboy2610
Start Scandisk.
Select drive.
Check the 'Atuomatically Fix Errors Box".
Choose either Stabdard or Thorough. (Thorough makes Scandisk work harder, but it takes longer).
Click the Start button.
Those are the directions in the book I have, anyway.
Old Nov 1, 2004 | 07:47 PM
Mike W's Avatar
Mike W
I used to use Norton Utilities to fix problems but I kind of got away from using them.
Old Nov 1, 2004 | 07:49 PM
Mil1ion's Avatar
Mil1ion
Right !
I did that.
The extra part is when it STOPS scanning & fixing automatically when it gets to the DIR files.This spot is around 29% through the scan.
Then I have been fixing one file at a time (2000+ times pressing enter)
That got old Real Quick
Hence....is there another way around this ?
Old Nov 1, 2004 | 07:50 PM
free90xlt's Avatar
free90xlt
When you are at the command line from the boot disk, type scandisk ? - it should show you a list of options you can enable when starting scandisk. I believe one of the options is to automatically fix errors.
Good luck,
Mike
Old Nov 2, 2004 | 08:16 AM
droptop's Avatar
droptop
Try starting Windows in safe mode and then run scan disk. It sounds like some process is running in the background while you're running scan disk. That is probably why it was hanging at 9% the first time you ran the scan.
Old Nov 2, 2004 | 05:48 PM
andym's Avatar
andym
Another trick is to create a DOS boot disk. I think you flip a check box on when you format a floppy to make one. Then copy the scandisk***** to that disk. Boot from the floppy, and run scandisk. There may be a command line option so it will automatically fix any errors, or it may do it by default. I can't remember, it's been a while since I've used windows 98.
bodabdan
Dec 15, 2007 10:03 PM
rmalottwtes30
Jun 6, 2007 12:12 PM
Nitramjr
13
Feb 28, 2007 11:31 AM
Patatoe1
Jan 16, 2007 01:14 AM
NRAJOE
Apr 3, 2003 02:58 PM
