no power
Old Nov 1, 2004 | 10:02 AM
danhrn's Avatar
danhrn
Angry no power
I replaced the starter and solenoid on my 1991 F-150, 4.9l 6cyl, 4 speed now I have no power when i turn the ignition switch, I have checked the fuses and I am about at my wits end, any ideas?
Old Nov 1, 2004 | 05:33 PM
Popa Tim's Avatar
Popa Tim
no power at all or do lights/radio/horn work?
Old Nov 1, 2004 | 05:44 PM
danhrn's Avatar
danhrn
no power at all, could it be a bad solenoid
Old Nov 1, 2004 | 06:52 PM
Fordnite302's Avatar
Fordnite302
a bad solenoid would have absoultely nothing to do with the reason why, noting works. you should check your battery cables, for corrosion, opens, shorts, stuff like that.
Old Nov 1, 2004 | 07:50 PM
mociaz3's Avatar
mociaz3
Trace it from the battery out, with a voltmeter. You may have hooked the feed from the battery to the starter incorrectly, or the feed to power the rest of the truck incorrectly. Since you just changed those electrical parts, Id go with a wiring mixup. I dont know your truck specifically, though. Good Luck
ford-harto3457
Sep 20, 2009 11:05 PM
61ford4u
May 30, 2008 07:30 PM
cajhicks
Feb 19, 2007 05:03 PM
tbird4
13
Feb 15, 2006 06:20 PM
Pi150
Electrical Systems/Wiring
Mar 1, 2004 05:18 AM
