No Power?
Old Feb 29, 2004 | 06:14 PM
Pi150's Avatar
Pi150
Question No Power?
I have an 87 F150 4x4 withthe 4.9 L engine. My problem is I have no power to my ignition switch. Any suggestions?
Old Feb 29, 2004 | 08:11 PM
sparky's Avatar
sparky
The power to the ignition switch is on a large yellow wire.....the other end connects to the starter relay-battery + terminal. There is a fusible link there, at the end of the yellow wire......maybe it is burnt out.......corroded terminal......does anything work on the truck....headlights, brakelights??????
Old Feb 29, 2004 | 09:08 PM
Pi150's Avatar
Pi150
Yes the headlights work, and if I jump the solenoid it turns over.
no heater fan, radio, or other accessories.
Old Feb 29, 2004 | 11:19 PM
sparky's Avatar
sparky
Well it could be the fusible link....since the headlights work the battery is suppling power and the ground is good...........or it could be the ignition switch itself.
........wait a sec doesnt the 87 model have the switch on the steering cloumn with the key activating it by pushing a rod against it....if so these break sometimes and turning the switch doesnt actuate the switch anymore because the rod is broken.........it has been discussed here recently with "how to" repair instructions included.
Old Mar 1, 2004 | 05:18 AM
prcrboy's Avatar
prcrboy
Not only could it be the rod, but don't forget to check the tranny safety switch. If manual, one for the clutch and if auto, one for nuetral safety.
rangergirl94
18
Jun 10, 2017 09:17 PM
Dusty F.
22
Sep 20, 2012 06:20 PM
ford-harto3457
Sep 20, 2009 11:05 PM
88FordF-150
General Automotive Discussion
31
Dec 9, 2005 08:21 AM
rooferted
Offroad & 4x4
Jul 2, 2003 07:42 PM
