Smoking Starter!!!!!!!!
Old Nov 1, 2004 | 10:00 AM
PSD6litre40's Avatar
PSD6litre40
This morning when I went to get in my SD I let the glowplugs heat, waited for the "curly-q's" to go off. I turned the switch and it barely turned over and then smoke emerged from the hood. I jumped in the truck and put in neutral and pushed it outta the garage because I thought she was gonna burn to the ground. After I got it outside I looked under the truck and smoke was still coming from the starter. What could this be? After it said for about 30 minutes, It cranked, but bvery very slowly. After I let the motor warm up, I shut it off and it immediatly cranked. I am gonna take it to the dealer and demand a starter replacement or something to that effect. Truck has 20,000 on it and is a year-old. What should I do?
Old Nov 1, 2004 | 10:09 AM
jdadamsjr's Avatar
jdadamsjr
Sounds like you may have not gotten the ground strap recall done maybe ????
Do you have squirrel parts left under your hood ?!?!
but You're doing the right thing !!!
Bet you didn't need that second cup of coffee to wake up after that
Old Nov 1, 2004 | 10:31 AM
kw5413's Avatar
kw5413
What is your engine build date?
Could it possilby be the "hot" ground cable that was recalled on the '03 engine builds?
Old Nov 1, 2004 | 05:42 PM
Hayapower!'s Avatar
Hayapower!
My 03 starter took a 'dumper' at 200 miles.. No smoke...But no crank either.. Never had the chance to get it in for the ground recall..
.....................HP...............
Old Nov 1, 2004 | 06:40 PM
Blackie60's Avatar
Blackie60
Sounds like the grounded cable is loose onto the engine as part of recall and did you get those fixed by recall? If not then it may be. Good Luck.
Old Nov 1, 2004 | 07:43 PM
PSD6litre40
No, i have not had that recall done that I am aware of. But, HECK NO I didn't need another cup!
AtlM5
Dec 13, 2015 07:57 PM
Subaru Sti
Sep 20, 2014 07:01 AM
InfidelReaper
Apr 2, 2013 02:54 AM
maxidog-ranger
4 Cylinder Engines
Feb 1, 2005 01:57 PM
GunNut
Jul 23, 2004 06:57 AM
