Help with 82 AOD 2w Drive
Old Nov 1, 2004 | 09:28 AM
slbrunk2's Avatar
slbrunk2
I am having an OD issue with my 82 F150 it has an AOD trans. I just replaced the trans due to the very same issue. I replaced it with a used transmission that I have used in the past. It will not up**** into OD and acts as it gets to shift and then can't quite make it up there. Feels like it is stuck in between gears. Lower gears work just fine. I found some technical service notices and no which one I want to look at but don't know where to find the actual bullentin so that I can read it.
Any help in find the bullentins or a resolution to my issue would be MUCH appreciated since I have spent over 4 full days trying to resolve the very same issue I seem to have with both transmission.
Old Nov 5, 2004 | 12:43 AM
ladiabla74's Avatar
ladiabla74
Does the speed top out at 55 and go past that on full throtel only and goes back to 55 when not at full throtel? If so then you got some issues with a solenoid. Don't know which one since I took an 86 I had with the described issue to a mechanich and got it fixed by replacing a solenoid.
Old Nov 5, 2004 | 10:04 AM
slbrunk2's Avatar
slbrunk2
To be honest I do not know because I have not pushed it that high of a speed at this time. I will do some more checking this weekend.
Do you happen to have any idea where the selonoid you speak of is located? I don't think the 82 has a selonoid but it would be worth checking out for sure.
2K RANGER
1983 - 2012 Ranger & B-Series
Aug 26, 2023 12:03 PM
tuckr
Mar 15, 2005 08:30 AM
slbrunk2
Nov 2, 2004 01:25 PM
GEDLAW
May 21, 2003 09:07 PM
