1978 - 1996 Big Bronco
Headlight troubles
Old Oct 31, 2004 | 08:00 AM
rayash56's Avatar
rayash56
Headlight troubles
Hi,
I have a 93 Bronco and I am having trouble with the headlights flickering on and off.Any ideas or help would be greatly appreciated.Thank you,
Ray
Old Nov 1, 2004 | 01:44 AM
ANdrewdrice's Avatar
ANdrewdrice
look behind your headlight and twist off the light bulb holder. change the light. if you have already done this, look at the wires from the headlight. baybe there is a lose wire in there somewhere. if you find a mangled wire somewhere, reconnect and buy some heat shrink stuff and fix it.
Old Nov 1, 2004 | 10:28 AM
greystreak92's Avatar
greystreak92
If you don't find anything out near the headlamps themselves, check the switch connector. Both my 92 and my 93 had problems in this area. The headlamp contact would heat up due to age and poor connection and eventually the contact on the switch would snap free from the switch. And its definately heat related because there is minor distortion of the plastic in the connector and the switch.
kefrko
Oct 21, 2013 08:42 PM
Bwetzel
Nov 20, 2012 12:40 PM
dmp1983
Nov 4, 2012 11:28 AM
birkblaes
Dec 29, 2006 07:47 AM
BC06PSD
Mar 4, 2006 02:01 PM
