Fuel additives
Old Oct 31, 2004 | 12:15 AM
TheDuke's Avatar
TheDuke
Question Fuel additives
Which Diesel fuel stabilizer have you guys had good luck with?<O</O
I hear allot of guys say use stanadyne but I am unsure which stanadyne product I should choose and where to acquire it.<O</O
<O</O
Old Oct 31, 2004 | 03:35 AM
drighten's Avatar
drighten
I have not tried Stanadyne, but I do use Howes Lubricator in winter, both for the lube and the antigel, and also a bit of Howes Meaner Power Kleaner in the warmer months to clean the fuel system up. Can't get bio additives up here in Canada yet, nor biodiesel anywhere except Toronto, and I live too far from there to fuel there, Ha!
Old Oct 31, 2004 | 09:04 AM
xlb3x's Avatar
xlb3x
http://www.stanadyne.com/new/ppt/ppt_dfa.asp
Try the performance formula. It seems to be the best all around formulation. The link above will give you all the info you need. The other companies products are all good. This one just seems to cover all the bases.
Old Oct 31, 2004 | 12:57 PM
SBV45's Avatar
SBV45
Stanadyne Performance Formula is what I use in the winter. I order it off the Internet.
http://www.dieselpage.com/add1.htm You can also get Fumoto Valves at that site.
Old Oct 31, 2004 | 05:48 PM
TheDuke's Avatar
TheDuke
I read that if you do not drive allot then you need to use a fuel stabilizer. I am currently burning a tank every 2-3weeks. Does the performance formula work as a stabilizer also?? If not what is good for a stabilizer?
Old Oct 31, 2004 | 07:30 PM
me1mckee's Avatar
me1mckee
Power Service- Walmart- Here in TX either white or grey is plenty of protection and stabilization and the choice is up to you depending on how much cetane boost you want.
Old Nov 1, 2004 | 05:10 AM
t_j82's Avatar
t_j82
Stanadyne is what the Field Service rep said to use.
Old Nov 3, 2004 | 09:33 AM
RyanF's Avatar
RyanF
I was also recommended to use stanadyne. Make sure you purchase stanadyne off of the net. I bought a bottle at a Ford dealer paid over $16 and I bought a case of 12 on the internet for less than $60 or for around $3 something a bottle.
Old Nov 3, 2004 | 10:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I have used Stanadyne since new EVERY fill-up 13oz....very happy with it.
Old Nov 3, 2004 | 12:03 PM
nosdog2's Avatar
nosdog2
Do you have a website? I havn't used any additive and I just turn 60K. Am I losing out on something? Should this be something that is a definate use for winter?
Old Nov 3, 2004 | 12:14 PM
Dr_Pain's Avatar
Dr_Pain
Try http://www.dieselpage.com/add1.htm... $47 + shipping
Claude
Old Nov 3, 2004 | 12:15 PM
RyanF's Avatar
RyanF
I would strongly recommend using an additivre a Ford diesel tech told me they can prove to be very benefical. Here is the website: http://www.dieselpage.com/add1.htm
Old Nov 3, 2004 | 12:18 PM
RyanF's Avatar
RyanF
Originally Posted by Dr_Pain
Found it on ebay for a bid of $56
Claude
Yea, plus shipping. The link I posted has it for $47.64 plus shipping, shipping for me was $9.91 and that was regular ground.
Old Nov 3, 2004 | 12:21 PM
Dr_Pain's Avatar
Dr_Pain
Beat me to my own correction there Ryan. Good job !!
Claude
Old Nov 3, 2004 | 01:35 PM
Busa Dave's Avatar
Busa Dave
I have a case of both of the Amsoil Products and one is a cetane booster which I used in my Duramax and are now using in my 05 F250. I think of it as preventative measures to avoid any problems later.
