Aerostar Ford Aerostar
92 2WD - No odometer or speedometer
Old Oct 30, 2004 | 07:01 PM
alanjsmith's Avatar
alanjsmith
My speedometer and oddometer stopped working about a week ago, which was great because my daughter stopped bugging me for 3 MPH over the speed limit. However, I need to get it fixed since my smog is due. I bought a speed sensor from Ford and went to replace it but it wasn't on the transfer case like the Chilton manual pictured it. I looked all over the trnny, transfer case and differential but couldn't find any part that matched the one Ford sold me and they said that was all they had for my van. Any thoughts?
Old Oct 30, 2004 | 07:43 PM
cookkd's Avatar
cookkd
Look at the transmission on the driver's side. There will be a wiring harness the first take-off is the automatic transmission connector. The second is the backup/neutral safety switch. This last item on the harness is the Vehicle Speed Sensor .
Old Oct 30, 2004 | 08:15 PM
alanjsmith's Avatar
alanjsmith
Unhappy
Thanks, that is exactly what the manual showed but I only have two take off's on the harness. I would have expected the sensor to be about 8 inches from the back of the tranny but there is only an impression cast in to the housing in that location. Any other suggestions?
Old Oct 30, 2004 | 10:07 PM
Ulf's Avatar
Ulf
I believe the speed sensor might be located on the rear axle housing, center or slightly to the right on the pumpkin on top...
Hope that helps.
Old Oct 30, 2004 | 10:48 PM
alanjsmith's Avatar
alanjsmith
I will saw that one when I was looking earlier today but wasn't sure that was related to the speedometer & odometer. I'll see if I can get a part tomorrow and replace it. Hopefully it solves the problem.
Old Jan 16, 2005 | 11:54 AM
Jim-in-RP's Avatar
Jim-in-RP
I'm wondering if changing the speed sensor worked for you...I didn't help me and I have the same problem. It's an analog speedo, but does get it's input from the speed sensor in the differential (it has rear ABS, so the speedo shares the sensor according to the owner's manual). Fuse, or something else I should look at next?
rbrungard2012
Dec 9, 2013 03:49 PM
rbrungard2012
Dec 6, 2013 12:30 PM
therealulysses
May 6, 2012 10:22 PM
jdcii
Aug 19, 2010 08:42 PM
Little Foot
Jan 4, 2007 09:38 AM
