best goo to seal the rear end with?
well i took on the project of changing my rear end fluid and ever scince its had a steady leak. nothing major but its not right. so what is the best goo to seal the hogs head cover with? anyone know.
p.s i did clear off all the old silicone off the housing and the cover. but to no avail i still have a small leak
Clean the surfaces well with disk brake cleaner.
Use a Permatex form a gasket type silicone.
I applied the silicone around the diameter of the differential, around the inside of the bolt holes.
I installed the cover and let cure overnight before filling with 75/140.
No leaks for over a year.
Another option would be to go down to the parts store and get a paper gasket for it.
Don't know what all the fuss is about. Clean the cover and the pig with solvent. Apply thin coat of Permatex blue to both cover and pig. I don't wait for them to skin. Bolt cover on. Let set up for about 1/2 hour and fill with lube. Used this process for many years on the Ford, Chevy and the Dodge and have never had an axle cover leak. Now that I've said that gona knock on some wood.
Randy
Randy
Originally Posted by cangim
Out of curiosity, what is the benefit of changing the diff oil? According to the manual you should never have to change it.
Yea I gotta go with Kwik on this one - that's a LOT of miles on that relatively little bit of oil in there. Unless I have a problem first - I was figuring on changing mine every 50K or so. I changed the rear oil in my old truck - slapped the cover on, waited a 1/2 hour and filled it with oil. The next morning - all (looked like it anyway) the oil was on the drive instead of in the diff. The next time I waited 24 hours and it held fine - so I wouldn't rush it.
The trick to get the silicone to seal is to completly degrease the contact surfaces. After you get the cover off and clean out the yucky oil and are ready to put the cover back on, get a can of brake cleaner spray and a bunch of rags. Thoroughly and I mean THOROUGHLY, and aggressively remove any oil from the sealing surfaces on both the pumpkin and the cover. Make sure that there is no oil going to run out of the housing and over the sealing surface. Only then is it ready to have the silicone applied. Then it will not leak.
Now while the cover is off, why not drill a small hole in the bottom of the cover and weld a nut on the inside, run a short bolt with a sealing washer through and you now have a handy drain plug for a much easier rear axle servicing.
