5.4L Error Code P0316
Old Oct 29, 2004 | 10:44 PM
whalerron's Avatar
whalerron
3 weeks ago, I started my 2002 Econoline after it had been sitting unused for 3 very rainy days. It has a 5.4L motor with about 48K miles. It was relatively hard to start and when it finally started, it ran very rough for about 2 minutes. I never had the problem before that and it hasn't happened since.
Last night I scanned the system and found an error code P0316 was reported.
P0316 = Engine Misfire Detected on Startup (First 1000 Revolutions)
Does anybody have an idea as to what caused this problem?
Thanks.
Old Oct 30, 2004 | 12:17 PM
beer boy's Avatar
beer boy
rainy days
i've heard of the 5.4l's with the "cop" set up devolping moisture under a coil. if it hasn't again that is most likely the problem. to prevent this you could remove each coil and apply dielectric grease to the tops of the plugs. but on a van this isn't an easy task.
Old Oct 30, 2004 | 09:17 PM
whalerron's Avatar
whalerron
Thanks. I was wondering about the moisture issue because not only had it been rainy but it was also very humid to the point of being foggy during that time. I had though the newer cars were not prone to ignition problems caused by moisture but I guess this proves me wrong. I will make not of the error code and clear it. Then I will check it every so often to see if it comes back.
- Ron
Old Nov 2, 2004 | 11:23 PM
brhanso's Avatar
brhanso
Thumbs up
I had the same problem a week ago. It got real Foggy and rainy out. When I scanned the codes , I had a P0304 and a P0316. I haven't had it since. But I've heard from others who had a smilar problem , and the coils were getting wet. Mine is still under warrenty, so I'm thinking of taking it back to be fixed.
MisterZ
Jul 21, 2021 02:07 PM
Trapper30
General Automotive Discussion
Jan 25, 2015 08:17 AM
joesnogood
Feb 26, 2014 10:18 PM
Long bed ford
2004 - 2008 F150
Feb 19, 2014 09:19 PM
jpeloian
23
Oct 31, 2011 09:49 AM
