OK to wash 7.3L
underhood fetish...
I have a fetish about detailing under hood of all my vehicles. If you really want to score big, first get engine hot. I took the air box, engine cover and intake pipes off, sealed the turbo air intake. Use 1 full can of aerosol engine cleaner and hose it down-use it all. After 5 minutes take a pressure washer, use safety goggles, and let her have it! Soon as your done, have a heavy duty spray bottle with armor-all or similar product, hose it down, pour remainder on hot exhaust parts and close hood. Let sit for 1 hour. If gas engine, a full day works better. Then I take silicone tire dressing and give it to her again!
Some good advise: Those who do not understand electronics will tell you not to do this. The fact is, all electronic components and connectors are weather-pac style and will resist the moisture-If one does fail, it was going to let go anyways.
This is a great help if you plan to work on engine like I had to, to replace 2 failed injectors.
Enjoy, Tony D.
Enjoy, Tony D.
I used a hose with a spray nozzle and nearly killed mine. Don't know exactly where I sprayed that I shouldn't have, but I suspect it was the two connectors near the top of each valve cover that caused my problem. She started up but ran very, very rough.
Brrrrrumph....Brrrrrumph....Brrrrrumph....Brrrrrum ph....Brrrrrumph....Brrrrrumph....Brrrrrumph....Br rrrrumph....Brrrrrumph....
It took a day to work itself out. Looks good though.
So just don't do whatever I did and you'll be fine.
Originally Posted by tonydshinycar
Hey All!
Crack the block by washing engine? Now that's a theory! Maybe I meant to say "warm the engine up first" instead of "get it hot" meaning get to operating temperature and let cool for a few minutes.
I meant no insults, only trying to help! Thanks, Tony D.
NOTE: Never wash the engine when it is warm, hot or running. Spraying water or other cleaning fluids on a warm engine can seriously damage the engine's fuel system. When washing the engine, the air cleaner must be in place to prevent water from splashing into the engine.
Hey All!
Thanks for your comments,
Luke
