there is a high pitch screech coming from the engine on my 390 what could this be the engine has plenty of oil pressure 78 psi and it turns freely what is it i was told it could be from running the wrong oil two thick i am running 20w50
If it's 70 degrees it ain't the oil. I would guess it's time to change to a lighter oil when it gets down around freezing.
Give us more info. Does it happen all the time? Is it louder at any time? Take you belts off and see if it goes away. If it does, determinewhich belt made the noise.
i ran it with all the belts unhooked to see if it went away and it did not so i am at a total loss now the sound is back and little louder it sounds like metal on metal
