Drive Train Vibration
Old Oct 29, 2004 | 12:45 PM
daniele's Avatar
daniele
Question Drive Train Vibration
I read that a couple of people had Drive Line or Drive Train Vibration problems. What do you exactly mean by that? What are the symptoms?
I have a 99 Ranger and I noticed that intermittently it will make a loud vibration sound. It sounds like it is coming near the back of the truck right under the bed.
I've looked and so far I can't find anything. It seems to run OK, just noisy.
It does it in any gear including Neutral.
Does anyone have a suggestion how to correct it?
Old Oct 29, 2004 | 04:49 PM
zamboni guy's Avatar
zamboni guy
drive train problems
This problem occurs every once in awhile due to the fact of moisture enters in rear end or in my case with a brand new 2000 ranger the rear end wasn`t acting like a limited slip rear end and caused the truck to vibrate and when turning corners acted like wheels were chatering. I had the rear end gear oil changed and had a fricton modifier added i hope this helps.
Old Nov 1, 2004 | 08:39 AM
daniele's Avatar
daniele
Thanks for the information. It turns out that I have something vibrating inside my muffler.
Old Nov 1, 2004 | 05:51 PM
rangersvt04's Avatar
rangersvt04
its you muffler bearings. Thats gonna cost a bunch and only a dealership hs the right tool
Old Nov 1, 2004 | 08:26 PM
Ken00's Avatar
Ken00
Glad to hear you found the problem, guess it's time for a new muffler.
LOL @ rangersvt04.
Old Nov 2, 2004 | 09:25 AM
daniele's Avatar
daniele
Talking
Thanks for the suggestion on the muffler bearings. I'll look into it when I get back from our family snipe hunt.
Old Nov 2, 2004 | 11:53 AM
tortoise_486's Avatar
tortoise_486
My '98 Mazda B2500 had developed a rattle at certain RPMs, and was thus intermittent. The sound was coming from the exhaust area. It turned out that it was just a shield around the muffler that had come loose and removing it completely solved the problem....
Old Nov 2, 2004 | 04:27 PM
MSRanger's Avatar
MSRanger
Ditto on having the external heat shield mounted to the catalytic converter break a weld, and rattle at certain times. The easy fix is to carefully break the other welds, and remove the shield, or if you're really fussy/picky, have a muffler shop try to weld it back on.
