IAC
Old Sep 18, 2002 | 11:34 AM
Ken00's Avatar
Ken00
IAC
Old Sep 20, 2002 | 09:05 PM
Hank85713's Avatar
Hank85713
IAC
I was having hi idle problems, disconnected the IAC and it idled OK. Replaced the IAC, it goes to hi idle, drops to normal, then goes back to hi idle. The manifold is clean, just wonderin if there is something at the butterfly that needs to be checked. Worst case is to take it back and get another if nothing else works out.
Any ideas?
Old Sep 21, 2002 | 09:42 AM
Critterhunter's Avatar
Critterhunter
IAC
Could be that the new IAC is bad out of the box. Also, make sure you don't have any air leaks around the new IAC gasket, then check for air leaks around the rest of the motor. I was having the same problem and I think I fixed it with a new O2 sensor after replacing the IAC but don't remember for sure.
Old Sep 21, 2002 | 05:28 PM
bubbernator's Avatar
bubbernator
IAC
Does your truck have A/C? If so, is it working right? I knew my IAC was going when it wouldn't compensate for the A/C clutch engaging-disengaging.
CB
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
