trouble starting
Old Oct 28, 2004 | 10:54 AM
tampabandit's Avatar
tampabandit
trouble starting
ok i need help again..i dont know whats wrong but im hoping somebody on here does..my truck wasnt starting and i didnt think it was getting gas because it had spark and timing wasnt touched from when it was running but the truck sat for a few months. Now i tried spraying starting fluid in the throttle body and it started right up and ran great for over 30 mins.i shut it off and it restarts with no problen.but if the truck sits for a few hours it wont start unless i give it a shot of starting fluid and again it runs fine...any ideas??thanx for your help...tim
Old Oct 28, 2004 | 11:03 AM
Miller357's Avatar
Miller357
Carb or FI?
Sounds like a cold start issue. Seems like you are acting as the choke with your can of starter fluid
Old Oct 28, 2004 | 02:08 PM
mattskn's Avatar
mattskn
check your fuel pressure. when was the last time the fuel filter was changed
Old Oct 28, 2004 | 02:22 PM
mike_2000's Avatar
mike_2000
It could be fuel pressure. I had a problem like that where my truck would run fine for 25 or 30 minutes idling then you drive it and it would go a few miles then stall, then I could usually restart it but it would be hard to start the next time. I eventually found that the fuel pump was weak after I changed it the truck has been fine that was about a year ago. Hope that helps..
LRMetric
15
Mar 25, 2013 09:20 PM
pablocruz69
Jun 2, 2011 11:53 AM
ech0sh4y
50
Dec 30, 2007 01:28 PM
hammer440
25
Jul 31, 2006 10:40 PM
bmlawson
Jun 10, 2005 09:23 AM
