Please Help!!!
Old Jun 9, 2005 | 10:20 AM
bmlawson's Avatar
bmlawson
Question Please Help!!!
ok so the other day i was dryving my 89 f-250 4x4 with the 351 down the interstate. i had the cruise on and all the sudden i started losing speed and the engine returns to idle. so i hit the gas and i get nothing in the way of increased speed. the truck revved almost like it was running on two cylinders.now i got it off to the side off the road and the truck started to idle really rough and then it just stalled. so i sat there for a second and i started it up and it seemed like it was back to normal. so i get back on the interstate and i got up to about 50 and the engine started to buck almwost like it wasn't getting any gas. so i pull over and it stalls again.. i waited a few minutes and started again and just let it idle. it idled fine for a few minutes and then it started to run rough and stalled again. so here i sit. please help me out guys thanks.
Old Jun 9, 2005 | 10:57 AM
ATC_250SX's Avatar
ATC_250SX
try a fuel filter, its sounds like it may be something simple like that
and if you havent changed it with steel tanks, its probly got some rust in it, plus its really easy to change. check your airfilter too.
Old Jun 9, 2005 | 07:05 PM
MemOrex's Avatar
MemOrex
Has the Check engine light came on?
Old Jun 9, 2005 | 07:08 PM
Popa Tim's Avatar
Popa Tim
Definitely check your fuel pressures and if they're ok I'd try a new tfi module if yours is mounted on the distributor.
Popa Tim
Old Jun 10, 2005 | 09:23 AM
bmlawson's Avatar
bmlawson
i changed the fuel filter and it still stall. i will check the furl pressure today. thanks everyone!
Jackedup25
2004 - 2008 F150
Jun 26, 2014 06:06 AM
Walt95
Dec 1, 2012 05:56 PM
4601ton
Jun 18, 2011 10:53 AM
