Starting Problems
Old Oct 27, 2004 | 06:09 PM
Phxjack's Avatar
Phxjack
Starting Problems
1999 Ford F150 4X4 with 5.4 Liter. Vehicle started and was running fine. Went to restart would not crank, click only. Cleaned terminals, tried jump start, wouldn't work, continued to try and finally started. Replaced battery (was told old one was fine). Same problem occurs. Replaced entire battery cable system (positive and negative harness) from Ford dealership. Problem gone for one day, then same problem re-occurs. Any ideas?
Old Oct 27, 2004 | 08:03 PM
paragod's Avatar
paragod
Did you check the starter relay and have the starter tested?
AnnieR
Mar 10, 2015 06:42 AM
biglawndog
Jan 5, 2012 10:11 AM
BlueOvalLover
Mar 24, 2010 08:17 PM
bluerage
Jan 17, 2010 09:52 PM
breslijo
Feb 10, 2006 03:47 PM
