Ford Excursion wont start, one click
Old Mar 9, 2015 | 08:54 PM
AnnieR's Avatar
AnnieR
2000 Ford Excursion only starts once in a while, other wise we hear one click when we try to start the truck (2WD, 5.4L). Battery test= fine. Replaced starter relay, didn't fix problem -> So, jumped the starter and it works fine -> Replaced ignition switch then neutral safety switch = same symptoms???
Old Mar 9, 2015 | 08:57 PM
Apocalypse's Avatar
Apocalypse
Ground wire if it's clicks.
Old Mar 9, 2015 | 11:09 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
x2, that click is almost universal across all vehicles for a bad ground. Pull the negative cable off and clean both the battery terminal and the cable connection. If that fails, check the negative cable for any breaks or corrosion.
Old Mar 10, 2015 | 06:42 AM
harley4jcs's Avatar
harley4jcs
ANNIE : WELCOME to the world of XXXs
Add your general lo-cal to your profile so we know where you are
Lots of helping hands around here
ovalhead72
16
Jun 7, 2014 03:53 PM
sasquatch999
Jul 27, 2007 09:14 PM
datzsun
Bronco II
Jul 21, 2007 04:53 PM
swhite005
Jul 6, 2005 04:21 PM
elstx
Oct 2, 2003 08:24 AM
