I been lookin at the stroker kits from rpm machine and kc, I was wondering If these kits are internally ballanced or externally? What balance are you using gtex? and who did you buy through?
Ego maybe I can help? Alot of your cheaper Kits require balancing....You better kits with rings wrist pins,rods, crank and pistons usually balance them within 2 grams....Hope this helps...
Im trying to decide who to buy a 416 stroker kit from....And then I was thinking is it internally or external because its a 428 crank? I would like a good kit I was thinking Keith craft his is about 1800 dollars.
I bought mine through Flatlander Racing. Their service was pretty bad, so I can not reccomend them myself. My engine is internally balanced. It's a 428 block, but the crank is a SCAT 4.125" stroke crank, and it was balanced at the machine shop. I run the standard 390 felx-plate.
Well anything that comes out of KCs shop is top of the line if he has had his hands on it.....And you allways want to go Internally balanced any time you can afford it... That way your not limited to having too run the stock externally balanced Flywheel or flex plate and damper... You can run any after market one...because they all have a zero balance!!
Russ,
I think you're losing it in your old age. The damper is not externally balanced. All FE balancers are neutral. It's only the flywheel end of the motor that is affected.
-Scouder
Scoot, I have been LOST!!! Everyone No's a balancer is Balanced? DUH!!!
Thanks for the imputs guys ill just get it from kc sounds good....and good luck on yours too russ!
Oh yes, I have been making my rounds, I have too run to Richmond in 2 weeks and get my block from the shop... roller cam bearing are installed and the bore will be done= 4.392" and the heads are Aluminum SCJBs Ported..
I'll have to wait until feb..to pick them up(payment plan) So it might be together this summer....and then I have the Fabrication to do for the new motor and trans...
WTF are you putting together russ? You better be putting some humongus heads on there for that bore size.
Shoot Kurt...where ya been bud.....I thought you knew I sold my 433 Cobra..and am going on to build a 521" Cobra...And the Heads are Jon Kaase Ported SCJs Flow about 370cfm Intake and about 240cfm Exh....
Russ
and PS..you did a pretty good job on those heads boy!!!
I wish I could afford a 4,5,6k block.....but I cant..so I had to go the poor man way,,, 385 series based... but it will still be about 10k in all..justfor me tobuy parts and the machining and all the port work...
It should make for a very, Interesting ride??? LOL!!!
