351W 84 Bare Bones
Old Oct 27, 2004 | 11:28 AM
Denver351W's Avatar
Denver351W
351W 84 w/o Emission Controls
I have a 351 W from an 84 Bronco XLT. I want to put it in a 60 F100.
Is it possible to strip off all of the emission controls on this engine and have it run properly. Any info is appreciated.
Old Oct 27, 2004 | 12:23 PM
Mike W's Avatar
Mike W
That will work. Are you going to use a carb?
Old Oct 27, 2004 | 12:43 PM
Denver351W's Avatar
Denver351W
Yes, I plan on it as it has a new Edlebrock 4bb on it. What I am looking for is instructions on what can come off and how to make the modifications. Thx`
Old Oct 27, 2004 | 01:08 PM
Mike W's Avatar
Mike W
Just take all the stuff off leaving the bare block and heads. The only thing you might have to do is to plug a hole in the end of the heads if a smog pump was used in it's past life.
Old Oct 27, 2004 | 02:28 PM
84-250's Avatar
84-250
get rid everything down to the bare engine, put 5 new vac hoses on, put on a duraspark 2 ignition, 4bbl carb and intake, new cam and go from stock to modified
Old Oct 27, 2004 | 07:42 PM
scottie2hottie's Avatar
scottie2hottie
Better yet, there's a company on the web that sells HEI style distributors(one wire) for Ford applications, both for streep and strip engines. If simplicity is what you desire, go this route!
Scott
Old Oct 29, 2004 | 06:59 PM
jeepkiller's Avatar
jeepkiller
what 5 vac hoses are you talking about?
QUOTE=84-250]get rid everything down to the bare engine, put 5 new vac hoses on, put on a duraspark 2 ignition, 4bbl carb and intake, new cam and go from stock to modified [/QUOTE]
Old Oct 29, 2004 | 08:01 PM
84-250's Avatar
84-250
vac canister, vac advance on dizzy, brake booster, soliniod between carb and carbon canister(if vac controlled), trans moderator (if c6)
theres also 1 or 2 lines off the carb i dont recall now
thats what i have on mine, there are more lines if you want any emissions stuff.
