Atlernator Swap Question
Old Oct 27, 2004 | 07:26 AM
The67Beast's Avatar
The67Beast
I have a 1967 ford truck with 1967 wiring. I am installing a 1994 351W engine that has been converted to carb. I want to use the serpentine belt system. My question is will it be ok to use a 1994 alternator with the 67 wiring? A 67 alternator had a larger pulley on it and was around 60 amps. The 94 will have a much smaller pulley and have more amps. Having a smaller pulley will make the Alternator spin faster. Anyone have any ideas in this area? I don't want to burn up my truck. And I know that March makes all kinds of conversion kits but I would like to avoid spending over $600 for a kit. Thanks.
Old Oct 27, 2004 | 10:28 AM
TheWiz427's Avatar
TheWiz427
Moved to Electrical.
Old Oct 27, 2004 | 10:43 PM
Franklin2's Avatar
Franklin2
It should work fine if you get it hooked up right. It will only put out what the old truck system demands.
Old Dec 8, 2004 | 09:34 PM
heatmon's Avatar
heatmon
Lightbulb Alternator Swap
Yes, this new alternator should work fine- just don't forget that the '67 had an external voltage regulator, the '94 has an internal voltage regulator. You''ll only be using the internal one right? You can eliminate the external voltage regulator.
Big Skier
31
Feb 27, 2019 07:21 AM
breezesboy
Dec 14, 2014 08:46 PM
Dyllan78
Aug 11, 2012 08:50 PM
tombogue09
Jun 11, 2012 03:24 AM
Big Skier
Jun 3, 2012 12:39 AM
