1997 Radio -- No Audio Problem:
Old Oct 27, 2004 | 04:05 AM
dking_79927's Avatar
dking_79927
My audio system went out recently with a loud popping noise -- Now No Audio. I changed the radio, still no audio. I replaced the rear amp mounted in the back on the sub-woofer, still no audio. Question = Is there any other amp or device between the radio and the speakers?
Old Oct 27, 2004 | 05:16 AM
Monsta's Avatar
Monsta
Sit. Stay.
Did you check the fuse??
Old Oct 27, 2004 | 02:41 PM
elbuencarlos's Avatar
elbuencarlos
There is an old radio that uses a pre-amplifier between the radio and the speakers, but I don't think it came in the '97 Expe. Do you have more data for your original radio?? Part number, CD, Tape, etc.
Old Nov 11, 2004 | 06:01 PM
dking_79927
I have traced my problem to a bad pre-amp, P/N F75Z-18B849-AB. Can you let me know where I can by a used one?
Old Nov 12, 2004 | 09:14 AM
elbuencarlos
Dick,
I did not find the part number you mention in the system, perhaps the right part number is F75F-18B849-AB. It will be quite difficult and quite expensive to find this amplifier in the aftermarket since it's quite old also, maybe discontinued. You may want to ask for it in a Ford Service center near you. I suggest to replace your radio with a "built in" amplifier, and re-wired all the way to your speakers, this will cost you less.
abyars111
Apr 9, 2017 10:39 PM
borntodubb
Jan 15, 2017 09:42 AM
csf
Jul 12, 2016 03:35 PM
abyars111
Dec 3, 2015 08:22 PM
plowhand
1997 - 2003 F150
Jun 16, 2012 08:31 PM
