I don't know if this applies to you or not, I have a power chip that isn't perfroming well at all. Its very jerky and the truck even stalls at times on the low end and high end. It has great power, just do not like the performance. Any suggestions? Gary sends
Take the chip out and see how it performs without the chip. This makes sure there isn't another problem that you are blaming on the chip.
Hey gary george, don't feel too bad I have looked three times and I can't find the area on the computer where the chip should be!
You have to remove the computer from the vehicle and then remove it from it's protective case. Once that's done there is a small access port on the back side of the computer that also has a cover that will need to be removed.
