Sponsored by: Real Truck
'Auto' down for pass. window?
Old Nov 2, 2004 | 11:21 PM
  #31
Gregsd250's Avatar
Gregsd250
I ordered one of these today.I have a couple of questions about the switch set up.
if i put the relay on the drivers side, does only the drivers side button become auto down? or does both driver and passenger buttons work the same? or third question,
do i need to purchase two relays so that both buttons are auto down? i want auto down everywhere !!! Thanks
Old Nov 2, 2004 | 11:31 PM
  #32
propellerhead's Avatar
propellerhead
You only need one and you can install it on the driver's side switch for the passenger window, or on the passenger's side switch for the passenger window. Either way, both switches will have the one-touch-down functionality. I have the PonyPerformance kit on the passenger side on my Mustang and either switch does it. Works great! Best $27 I spent on my car.
Old Nov 3, 2004 | 12:57 AM
  #33
Gregsd250's Avatar
Gregsd250
Thanks for the great information. I was hoping it would work that way.
Old Nov 3, 2004 | 11:43 AM
  #34
superv10's Avatar
superv10
Yep, just installed it in my new 05 couple of days ago - put it on the passenger side - works awesome!!!
superPSD
Old Nov 3, 2004 | 01:55 PM
  #35
GloNDark's Avatar
GloNDark
Ordered mine, got 3 of em to do the passenger and rear windows of my crew cab. AWESOME!!
I wonder if there is a way to wire one on the "up" side of the switch.......to be auto up?? hhmmm Gonna have to try it.
Old Nov 3, 2004 | 04:25 PM
  #36
superv10's Avatar
superv10
GloNDark - let is know on the Up part - that would be way cool - make my Crew windows work like my BMW windows do..
superPSD
Old Nov 4, 2004 | 11:40 PM
  #37
roadturtlepsd's Avatar
roadturtlepsd
I INSTALLED THE POWER DOWN WINDOW KIT. IT WORKS GREAT. IT TOOK ME ABOUT AN HOUR. THEY CHANGED THE WIRE COLORS. I TALKED TO TONY AT www.webelectricproducts.com/products.htm. HE WILL UPDATE WIRE COLORS FOR 2004 F250 PSD CREW. IT WAS WORTH THE MONEY AND TIME IT TOOK TO INSTALL IT.
Old Nov 4, 2004 | 11:42 PM
  #38
roadturtlepsd
I DON'T THINK FERDERAL LAW WILL ALLOW IT. A CHILD MIGHT GET TRAPPED IN THE WINDOW. JUST A THOUGHT.
Old Nov 5, 2004 | 06:44 AM
  #39
SMc's Avatar
SMc
So the part listed for the ford on webelectricproducts website will work on all Fords (03 SuperDuty)?
Old Nov 5, 2004 | 06:58 AM
  #40
iskybantilus's Avatar
iskybantilus
hmmm
this problem seems interesting to me ..... i just tell my gurl .... "hey, window down" .... and sure enough, she rolls it down ... and when we get there ... 9 times out of 10, it automatically goes up .. i dont even have to push a button or say a thing ..... amazing isnt it?
guess its an XL thing
Old Nov 5, 2004 | 09:57 AM
  #41
Tckhan's Avatar
Tckhan
It works on all "00 through "05 SDs. By the way it looks, it should work on any power window. Also thinking that if you reverse the switch signal wire. It should be auto up ?? You'd need two modules then to do up and down
Old Nov 5, 2004 | 03:14 PM
  #42
OverHeight's Avatar
OverHeight
How does the window know that it has reached the bottom? Is it resistance in the electrical that stops the auto switch? If thats the case then would that not work going up? And then if you stuck your arm in there it would stop, but still have pressure?
Old Nov 5, 2004 | 04:07 PM
  #43
roadturtlepsd
I TRIED STOPPING THE WINDOW FROM GOING UP WITH MY HAND. IT DID NOT STOP. I GUESS THERE IS A LIMIT SWITCH TOP AND BOTTOM. THAT IS ONLY A GUESS IF ANYONE ELSE KNOWS THE ANSWER I WOULD ALSO LIKE TO KNOW.
Old Nov 5, 2004 | 09:50 PM
  #44
Kadukoboy's Avatar
Kadukoboy
That shizzle is PIMP!!!....I KNEW U GUYS WERE GOOD FOR SOMETHING!!!
BEERS ALL AROUND!!!!
Old Nov 6, 2004 | 05:41 PM
  #45
Fredvon4's Avatar
Fredvon4
Ordered from Pony Performance Thursday received today 6 November and installed in 20 min. Used the schematic Munkey posted and verified the colors for my 2005 were the same. They were/are.
Cut the Red/yellow tracer and tied the module red wire to the motor side and tied the module white/black tracer to the switch side. Added the module yellow wire to the yellow/red tracer between the switch and motor. My 2005 acc/run hot wire is the Yellow/light green tracer and that was tied to the module with the yellow/green or blue/black (depending on the supplied connector form Pony Perf). I drilled a small hole in the door steel and grounded the module black wire to it with a short sheetmetal screw. Done, got one touch down from both switches and if you hit the up it will stop.
After I was done went to all the other door switches and verified that the schematic Munkey posted is true to my 2005 window wires!
Too cool, great mod thanks fellows.
