1978 - 1996 Big Bronco
What Tires????
Old Oct 24, 2004 | 05:36 PM
dammford's Avatar
dammford
Question What Tires????
what tires ???? 1990 bronco stock..for now.. need good snow and mud? but i do have to drive this beast every day to school and work??? any suggestions??
Old Oct 24, 2004 | 11:38 PM
93BigBlackBronco's Avatar
93BigBlackBronco
Go with stock size maybe a little bigger. Light truck M/S (mud & Snow).
Most tire shops will tell you reccomended size for your rig. Brand makes a diffference you get what you pay for. Higher treadwear number = more miles. If you live in the Northwestern United states Les Shwab can't be beat for service and range of quality.
Costco currently has deal on Michelins $60.00 off set of four I just bought a set for the wifes GMC Safari van. Both places I listed include road hazard rotation and balance in price of tires.
I would recommend an alignment as well as check frontend for worn out parts Bronco's eat tires without proper alignment.
Old Oct 25, 2004 | 06:29 PM
dyarumian's Avatar
dyarumian
Get some all-terrains, there good in the mud and great in the snow and they will last you a whole bunch longer then some Mud terrains. As for size i like the way some 32X11.5" fit inside the wheel well and mine only rub against the radius arm in the front when i cut it all the way.
Old Oct 25, 2004 | 07:44 PM
dammford's Avatar
dammford
i like the look dyarumian! you got me thinking i was going to go 31,10.50'' but may be 32''
Old Oct 25, 2004 | 10:02 PM
WhëëlMå1's Avatar
WhëëlMå1
I loved the 31" Michelin LTX A/T's I had on my 96. It just ate up the snow!
Old Oct 25, 2004 | 10:27 PM
Str0ud's Avatar
Str0ud
BFG AT/KO Best compromise tire out there. Great in snow & ice, not too shabby in the mud either. They seem to last forever on my trucks, around 60-70K miles.
Old Oct 26, 2004 | 02:38 AM
aurgathor's Avatar
aurgathor
I wouldn't use larger than 31" on a stock Bronco. For one, it may rub a little, but that's a lesser issue. With the taller tires, the combined gear + tire ratio will change enough so the engine may not be running in its optimal powerband. On a completely flat terrain, this is no big deal, but on a hilly terrain it will be noticeable. You'd probably need 3.73, or 3.90 gears for those taller tires. Additionally, even though with a (functional!) 4WD it may never be needed, but if you ever need to instal snowchains, you want to have a little extra space in there.
Old Oct 26, 2004 | 09:10 AM
jimandmandy's Avatar
jimandmandy
Bridgestone Dueler A/T's get my vote. Dont go too big or you will have no power. 3.55 gears and .71 overdrive cant take much in the way of oversize tires.
Jim
Old Oct 26, 2004 | 09:37 AM
djjoshuad's Avatar
djjoshuad
I'm running 33"x12.50" BFG AT/KO and my truck is just fine on power. I've got a stock 351w with a few little cold-air mods, but nothing major. stock gears, stock everything. The truck had 31x10.50 on it when I bought it, and I noticed no performance decrease when moving to 33x12.50. It just looks much better
Old Oct 26, 2004 | 06:18 PM
Blue'87GT's Avatar
Blue'87GT
Is this on the stock rims? I'm wanting to get some real tires and 32x11.50's are on my list, but if bigger is possible without lift, then I'm willing! BTW, I've got a '96 with the "styled" steel wheels.
Old Oct 26, 2004 | 06:26 PM
Black Ford XLT's Avatar
Black Ford XLT
tires
bf goodrich allterain youll like em
Old Oct 26, 2004 | 07:18 PM
Blue'87GT's Avatar
Blue'87GT
32x11.50's a good all around size without interference?
Old Oct 26, 2004 | 07:46 PM
dammford's Avatar
dammford
thanks for the info!! i love this forum. i tried to talk to the tire shop people and got a bunch of crap!! THANK YOU GUYS
Old Oct 26, 2004 | 09:13 PM
WhëëlMå1's Avatar
WhëëlMå1
Blue'87GT: That really depends on the condition of your springs. They should work fine, but if you have really saggy coils, you might get some rubbing. If there is any rubbing, it should only be at full lock anyways.
Old Oct 27, 2004 | 10:09 PM
Salmonhead's Avatar
Salmonhead
You can adjust the frontbumper out a little ways and trim/remove the air dam in front. In the back I added tuff country add a leafs for under $100. Overall for power & clearance, you'll probably be happier with 31's unless you can change your gears to 4.11's.
