Sponsored by: Innova
Eclipse 5341 No Rear Speakers
Old Oct 23, 2004 | 08:17 PM
7K42S's Avatar
7K42S
Hi,
I just bought a 94 Lightning with a Eclipse 5341 CD Player. It was bought from a used car dealer and has no instruction booklet. What is happening is there is no rear speaker output. The wiring is all good and the front works fine. BTW I am just using the internal amp.
Old Oct 24, 2004 | 08:01 AM
kontai69's Avatar
kontai69
Many people do not use rear speakers (rear fill) to improve the acoustics or "soundstage." You can pull the head unit out and check to see if the rear speaker outputs are hooked up. Also, check to see if the rear speakers are hooked up or even there. I have a hard time believing that it's just the rear internal amps that are blown out.
Old Oct 24, 2004 | 10:13 AM
7K42S's Avatar
7K42S
The first thing I did was pull it out and everything is hooked up. If you hook the rears up to the front out put they work fine and the front dont work.....
Old Oct 24, 2004 | 11:30 AM
kontai69's Avatar
kontai69
I could also be the fader control. Make sure it isn't turned all the way to the front. I have never used Eclipse stereos so I can't tell you how to do it.
You may also ask the question over at...
http://forum.sounddomain.com/ubb/ult...?ubb=forum;f=8
DeathSpiral
Mar 21, 2010 01:38 AM
sandaholics
Oct 9, 2007 07:27 PM
Beerstalker
Jan 12, 2007 03:43 PM
FastEddie300
Sep 8, 2004 05:06 PM
