3.0 FFV check engine light
Old Oct 31, 2002 | 09:59 PM
Xizang11's Avatar
Xizang11
i have a 99 ranger with 3.0L flex fuel engine.
the check engine light won't go off.
OBD-II codes say "fuel too lean on banks one and two"
truck has 168,000 miles so i expect stuff to break, like that stupid airbag cutoff switch ($65). but i don't know what on earth to do about that. not like the old days when you just take a screwdriver to the carb.
Old Nov 2, 2002 | 07:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
Looks like nobody here knows much about flex fuel engines.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Nov 2, 2002 | 07:15 AM
TOUGHLover's Avatar
TOUGHLover
I have the same `99, 3.0 FFV - and I couldn't give you a clue (though it sounds like, and forgive me, I'm just on my FIRST cup of coffee - fuel inject. issue) you might try to track down Ken00 or check over in the "Fuel" forum - good luck . . .
Old Nov 2, 2002 | 01:24 PM
Rand's Avatar
Rand
When was the last time you replaced the O2 Sensors.
That sounds like a classic problem. I think you are susposed to replace them like every 60000 miles anyway.
If you have a vacuum leak it might be doing wierd crap like that too... unmetered air is bad...
Rand
Old Nov 6, 2002 | 08:20 AM
JohnBon's Avatar
JohnBon
Check the MAF...i had the same problem..same codes..truck lacked power..unplugged the MAF..and purrs like a kitten..I have read that when the ECU reports error of both banks running lean..it is rarely the 02 sensors (since you would need multiple simultaneous failures)..anyway..MAF for me..good luck!!
Old Nov 6, 2002 | 09:01 AM
fordlvr25's Avatar
fordlvr25
My check engine light went on last night the truck only has 33000 miles on, any idea what anyone thinks that it may be?
Old Nov 6, 2002 | 03:38 PM
bkarr2000's Avatar
bkarr2000
Old Nov 6, 2002 | 07:51 PM
TOUGHLover's Avatar
TOUGHLover
Post 3.0 FFV check engine light
DPFE (differential-pressure-feedback\sensor) is very common - do you tend to fill fuel more than a gallon or so past the pump clicking (cutting\shutting) off automatically? I did, and a mechanic told me that could cause it - fumes backing up from the charcoal-canister (from over-pressurizing the fuel tank\system)cause corrosion at the hose-sensor connection - at least that is my recall of the explanation.
It "appears" to be an easy fix (location very accessible) and cost "around" $60.
Mine occurred at around 40-45,000 miles, comes back as an "EGR"-related prob. but was told and have read that that is very often the case\cause (root) of the prob.
Best to have it properly tested\checked though before buying and changing parts if possible.
Also there have been TSB's on this - so maybe Ford ought to eat a portion of this cost\expense.
Best of luck, Glenn . . .
Old Nov 7, 2002 | 10:01 AM
Ken00's Avatar
Ken00
I would be a little surprised that both O2s would go at the same time. Look for vacuum leaks, dirty MAF, exhaust leaks and dirty fuel filter/low fuel pressure. If you would like the pinpoint tests send me an email and remind me of the code numbers.
Old Nov 7, 2002 | 10:03 AM
Ken00's Avatar
Ken00
If your still under warranty let the dealer fix it, if not you need to have the codes pulled, don't start replacing parts without knowing whats wrong.
Old Nov 8, 2002 | 08:29 AM
fordlvr25's Avatar
fordlvr25
hey ken00, 33,000 miles huh, that is when mine went on, and it wont shut off, going to check it out this weekend to see what could be the problem. let us know if you figure out what is wrong with it.
Old Nov 8, 2002 | 11:12 AM
Ken00's Avatar
Ken00
That was a quote from your post and I responded below.
Old Nov 8, 2002 | 12:16 PM
fordlvr25's Avatar
fordlvr25
what did you say, because i dont see it?
Old Nov 8, 2002 | 03:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Read post #8, if you can't see his reply you dooo have problems.
astrieby
Dec 6, 2014 08:47 PM
sbappleg8
Jan 28, 2014 07:52 PM
kwjaspen
Oct 31, 2009 04:44 AM
Benaghetto
15
Jan 23, 2008 03:10 AM
John H III
Jul 27, 2005 08:37 AM
