oil presh prob
Old Oct 22, 2004 | 03:32 PM
fiittllc's Avatar
fiittllc
oil presh prob
I have a 1990 e150 with a 302 in it. I just put in new lifters and pushrods becuase i had several sticking lifters. we also changed the oil pump becuase of low oil presure. I check the main and rod berings and they where well within spec. when i started the moter it started makeing a valvue taping noise but from the middle of the engine. afterr it runns for about 3 min the oil presh starts to jump up and down. ( I have two gauges one oem and one mechanical) and then about 30 sec latter the mech gauge drops to 0 and then the oem drops to 0 about 45 sec latter when this happens you can here the moter get louder so it is obvously loosing presh. the motor has about 89,000 miles on it. any ideas also when turning the motor over by hand there is a tight spot where it takes two people to turn the motor past it. this is present with or without plugs in and also with or with out the valve train conected. please help
erik
Old Oct 22, 2004 | 09:16 PM
pfogle's Avatar
pfogle
Sounds like either a bad gasket on the oil pump, bad oil pump, bad oil, or bad cam bearings. If it was my truck I would have gone ahead and replace the mains while I had the motor out, it's better safe than sorry.
Old Oct 25, 2004 | 10:30 PM
fiittllc's Avatar
fiittllc
thanks. it could very well be the cam bearings. do you think a cam bearing noise could be mistakin as a valve tap? thank you
Old Oct 26, 2004 | 12:49 AM
pfogle's Avatar
pfogle
It could be, does it run rough?
asder
Modular V10 (6.8l)
27
Dec 9, 2008 03:47 PM
tude
4 Cylinder Engines
Jan 2, 2006 11:52 AM
I_Thnk_Ford
3.8 & 4.2L V6
Oct 28, 2005 06:56 PM
Scoarch
Nov 12, 2003 12:59 AM
