multi carb linkage setup
Old Oct 22, 2004 | 02:20 PM
e william's Avatar
e william
Anybody running a multi carb setup with the old Holly two barrel that can send some pictures of the linkage?
I'm setting up a 2x2 setup on my 54 and wanted to see the setups so I can decide on a hard linkage or try a vaccume (progressive) type setup.
Any info is appreciated.
Thanks, ed
Old Oct 22, 2004 | 04:18 PM
himmelberg's Avatar
himmelberg
I've got a picture of my linkage... it is progressive linkage on 3 Holley 2 barrels... don't think it would help with your 2 x2. Also don't understand the vacuum setup question.
Progressive linkage is where your primary carb is linked normally and the secondary carb is engaged by a sliding hardpoint that begins to open the throttle plate at a designated point. In other words, when your primary is opened past , say, 60%, the secondary is opening dumping more fuel and air into the mix.
progressively, himmelberg.
Old Oct 22, 2004 | 04:33 PM
286merc's Avatar
286merc
What brand intake is the 2x2 ?? Dual carbs are usually hard linked and function as a pair at all times. Converting to progressive can be done with some creative work but you also get into a flow problem as the manifolds are not designed for that.
Is this for that 239 you have been playing with?
Old Oct 23, 2004 | 05:21 AM
e william's Avatar
e william
Hey 286Merc,
Yep, its for the old 239 I'm tinkering on. The intake is actually my stock 2 barrel, what I found was a reproduction y-adaptor (Vintage-Speed is reprod. the "Almquist" brand). I have also done more digging and found that the two carbs would throttle in tandum like you say. A friend had offered up the "progressive" term from his experience with dual 4 barrels where the first would somehow control the second with vaccume.
And I agree that my old Holley wont create anywhere near that kind of pull.
I bought a 55 intake , Holly carb and stock linkage for $15 and figured in the worst case it would be used for backup parts.
I'm not looking for race track performance, just a strong running-cool looking setup that is a little different than the norm. When I rebuilt the motor I would like to bring it back up a little different....electronic ignition, carb setup...etc, just a little stronger. It gives me an excuse to be in the garage !!!
Ed
Old Oct 23, 2004 | 06:50 PM
286merc's Avatar
286merc
Those Y adapters are making a comeback but they didnt work very good even when new.
Why not just use a 256 4bbl intake and mount a WCFB or 4G carb??
Or for something crazy get an old racing tunnel ram and hollow it out and place over the stock setup. Then put a honking big Holley on top, dummied up with the insides opened up!! Thats something Fenders would probably do.
GO RED SOX!
Old Oct 24, 2004 | 07:26 PM
oldfordtrucker's Avatar
oldfordtrucker
Please do not consider this an attempt to hijack your thread. I have no info to provide, but have similar questions to yours and hope I can learn something from future responses. Can anyone suggest a good manual or book to set up multiple carbs? Has anyone tried a vacumn setup on the end carbs? I recently bought a 29 Ford with a nailhead Buick engine with 6 Holley 94s on a log mainfold. Information on setting these old units up is hard to find. Any help will be appreciated.
Old Oct 24, 2004 | 08:46 PM
286merc's Avatar
286merc
About the only way to set carbs up is with a Unisyn & vacuum gauge. It also helps to have a friend with an exhaust gas analyzer in his shop.
As far as that nailhead (any displacement) that is way too many carbs for the street. Id dummy up the 4 outer ones.
I had a 394 Olds with Offy log and 6 97's some years ago. I had to dummy the ends for the street and open for the strip.
cstephens
Dec 19, 2022 06:26 PM
51phil
Jul 19, 2015 10:10 AM
Jerk
Jul 7, 2015 02:06 PM
rtcabal
Nov 24, 2014 09:19 AM
bigwalt1
Jul 16, 2014 08:14 PM
