What hardware to bolt in radiator support in '53 F100
Hello all,
I bought my truck in pieces so I'm not really sure how some of it goes back together. I wanted to bolt in my radiator support last night but I couldn't figure out what hardware to use since the frame crossmember has to large rectangular holes in it where the rad bolt support bolts in. Do I use a cage nut or is there some other special nut that I have to use to fill the holes.
Mid fifty doesn't list anything so I'm not sure what to use. Any help will be appreciated. Thanks much - Brad
Brad
I guess there is a little nut plate that none of us outside Arizona have ever seen before. I suggest a bolt and a nut with big washers. Allow yourself just a little room to adjust the radiator support during front clip alignment. Not quite stock, but damn handy if your cab has moved 1/4 inch, or you have a collection of stock and non-stock body panels.
barryjdi
11-24-2014 10:32 PM
Area351
07-05-2013 08:04 PM
farmnaggie
09-15-2011 08:16 AM
eddiey
04-21-2009 01:05 AM
TheWiz427
12-18-2008 01:48 PM
