Sponsored by: Real Truck
4R100 Trans DTC code P1744 - HELP!
Old Oct 22, 2004 | 06:07 AM
kenneBF250V10's Avatar
kenneBF250V10
Anybody out there ever get this code from their tranny? If so, what causes it and what was the fix? Did a search on the web and found it described as "Torque Converter Clutch System Stuck in Off Possition". I got it yesterday when my overdrive light started flashing and the truck didn't hardly want to move. Any assistance would be appreciated.
Old Oct 22, 2004 | 07:49 AM
Fredvon4's Avatar
Fredvon4
Never had a tranny problem but if I was you I would climb under, disconnect the electrical plug to the trans, inspect the contacts to make sure thay are not corroded, clean them if they are and reattach.
Disconnect battery while doing this to reset the computer and as a plain old safety precaution when working on electrical stuff.
Restart and drive to see if problem and code are fixed.
Hope this helps (HTH)
allingeneral
Sep 25, 2011 04:47 PM
fordfan610
Nov 29, 2010 10:41 AM
kenneBF250V10
Apr 16, 2008 09:29 AM
mmozdzierz
Jun 1, 2006 07:53 PM
hallaalex
Jan 30, 2004 10:02 PM
