C6 Questions
Old Oct 21, 2004 | 03:50 PM
desperado_18_2000's Avatar
desperado_18_2000
C6 Questions
In my 83 F-100 i have a C6. Dunno if its any good or not. I'm looking for a way of determining if the tranny still may be good other than bolting it back in behind the 300 six.
Fluid isn't burnt smelling, nor black, but kind of a reddish brown color.
I haven't dropped the pan to inspect for metal shavings yet...i plan on this soon.
Any way to determine if a pump, etc has bit the dust??
Thanks in Advance.
Old Oct 23, 2004 | 10:50 PM
good 'ol ford's Avatar
good 'ol ford
no u cant bolt a c6 to a 300 six cuz the belhousing pattern is different
Old Oct 24, 2004 | 12:33 AM
mark a.'s Avatar
mark a.
C6's came in all different bolt patterns. I wouldn't be alarmened if you see some crap in the pan , if it worked before it should work again.
Old Oct 24, 2004 | 10:55 AM
desperado_18_2000
The 300 and the smallblock fords share the same bellhousing bolt patterns. Any smallblock V8 trans will bolt to the 300 without a doubt. The ones that won't work are the ones for the FE series and the 429/460's. Also the 351M/400's won't work either.
I hope it does work, its not going to be pretty to shell out the $$$ to get 'er fixed.
