Mazda 5 Speed Probs
Old Oct 21, 2004 | 01:19 PM
vohaul's Avatar
vohaul
Cool Mazda 5 Speed Probs
hey guys
on my 92 f150 4x4 302 / mazda 5 speed...the tranny is sooo stiff in the mornings (when its colder..)...1st is useless, and even 2nd is hard to get into...after awhile it gets easier...but still stiff....
truck doesnt grind gears when it shifts, and there appears to be no slippage in the clutch......
any ideas on what the cause for this is..bad synchros, tranny fluid??
cheers,
Paul
Old Oct 21, 2004 | 04:42 PM
whimsey's Avatar
whimsey
I've have that tranny in my 2002 and had it in my 1989 truck. If you haven't changed the tranny fluid (ATF) I'd do it. It really needs changing every 30,000 miles. In my 2002 it was difficult to shift when it was cold outside with the factory Mercon. I changed to a synthetic blend Mercon and the shifting improved 100%. My 1989 truck had problems getting into 1st gear. But that was a continuing problem with the clutch slave cylinder.
Whimsey
Old Oct 22, 2004 | 05:16 PM
66gpw's Avatar
66gpw
Wink The trans sticking.
I have to agree with that the trans oil needs to be change. It sounds like it is a thicker blend and lost it viscosity. Change the oil and put synthetics in. Costs more , but in colder temps. it really helps the shifting. Make sure you put in the right weight of oil.
Econoline 150
31
Aug 25, 2009 04:24 PM
4.9LFord
Apr 20, 2005 07:30 PM
first time 4x4
Feb 15, 2004 03:45 PM
coolgreen
15
Oct 11, 2003 10:14 PM
1988-Ranger
1983 - 2012 Ranger & B-Series
Jun 30, 2003 01:10 PM
