speedometer cable removal
Old Feb 15, 2004 | 10:00 AM
first time 4x4's Avatar
first time 4x4
Question speedometer cable removal
I am changing the clutch and the only thing that is holding me up is removing the speedometer cable. I think it's the speedometer cable. It is the cable that is pretty stiff and goes in to the driverside towards the front and top of the tranny. tranny is one of those mazda 5-speeds. I don't know if it just pulls out or what. Hopefully it comes out easily. Help would be appreciated. Thanks.
Old Feb 15, 2004 | 11:58 AM
ecarter50's Avatar
ecarter50
Speedometer cable goes to back of trans on 2wd, back of transfercase on 4wd. What you describe is the hydraulic clutch line. It has a quick disconnect fitting you remove with tool #T88T-70522-A or equivalent.
Old Feb 15, 2004 | 03:45 PM
first time 4x4
Tahnks a lot. The clutch kit comes with the tool to remove that. I geuss I'm good to go then. Thanks again.
Jay94250
Mar 3, 2013 12:50 AM
limeyellowfellow
May 15, 2012 08:26 AM
ken selvy
Aug 30, 2006 03:07 PM
hemiyota
May 6, 2006 06:56 AM
oldnnew
Jul 24, 2004 06:31 AM
