72 rear
Old Oct 21, 2004 | 12:53 PM
72ford360's Avatar
72ford360
72 rear
does any one have an idea on what the 72 ford f250s with the 360 and 4 spd stick have on rearend gears???
Old Oct 21, 2004 | 12:55 PM
4x4Subaru's Avatar
4x4Subaru
Is there a tag on it?
Old Oct 21, 2004 | 01:33 PM
WillyB's Avatar
WillyB
It is listed on your rating plate - the last 3 digits of the Axle code is the ratio. The books show that you could have any of the following ratios, depending on which axle was installed:
3.00, 3.25, 3.50, 3.54, 3.70, 3.73, 4.09, 4.10, 4.11, 4.56, and 4.88. Some of these are for the 1/2 ton, and I think the 4.88 was only available in the 1 Ton.
Old Oct 21, 2004 | 04:05 PM
72ford360's Avatar
72ford360
where can i find the axle code or the rating plate??
Old Oct 21, 2004 | 04:11 PM
72ford360's Avatar
72ford360
i went to look on the door and under axle it says 38.thats all i could find
Old Oct 21, 2004 | 05:18 PM
WillyB's Avatar
WillyB
Code 38 in my book is for a Dana 60 axle with a load rating of 5200 lbs and a ratio of 3.73.
My guess is that will be a little low for the highway, but not as low as the real stump pullers. A good compromise - but not the greatest for economy in a daily driver.
Old Oct 21, 2004 | 05:41 PM
72ford360's Avatar
72ford360
Thumbs up
yeah i thought i had some knid of low gears cause it feels like its revving pretty high in the freeway.but theyre allright i just wanted to know what kind of gears i had so in case i want to change em.thanxs for all the information
Old Oct 21, 2004 | 05:46 PM
72ford360's Avatar
72ford360
oh also now that i know what kind of gears i have what axle codes are for the 3.50 or 3.54 ,3.25 so i could look for this at the junkyard.over here in california you see them somewhat and instead of taking the rearend apart just to find out it has the wrong gears.like this i could get a rough idea on the ratio before getting to work.
Old Oct 21, 2004 | 07:01 PM
Boyd1971's Avatar
Boyd1971
The Rear Axle code: The first two digits represent the rear axle and the third represents the front axle, if applicable.
FRONT AXLE CODES
Capacity
Code
5,000# Ford A
5,500# B
6,000# C
7,000# D
3,500# Dana 6CF HD K
3,000# Dana 44 lock L
REAR AXLE CODES
Ratio & Type Code
3.54 - Dana 5250# 37
3.73 - Dana 5250# 38
4.10 - Dana 5250# 24
4.56 - Dana 5250# 25
3.54 - Limited Slip Dana 5250# C7
3.73 - Limited Slip Dana 5250# C8
4.10 - Limited Slip Dana 5250# B4
3.25 - 3330# Ford 17
3.50 - 3330# Ford 08
3.70 - 3330# Ford 09
REAR AXLE CODES
Ratio & Type Code
4.11 - 3330# Ford 05
4.00 - 3300# Ford 02
3.70 - 3300# Ford Limited Slip A2
3.50 - 3600# Ford H2
4.09 - 3600# Ford H3
4.10 - 5200# Dana 70 27
4.56 - 5200# Dana 70 28
3.73 - 5200# Dana 70 36
4.88 - 5200# Dana 70 22
4.10 - 7400# Dana 70 Limited Slip D7
1972fordhighboy
27
May 10, 2017 01:19 PM
greentruck72
27
Oct 4, 2016 03:47 PM
adamflow
Mar 11, 2016 12:14 PM
jdsunset
May 2, 2012 07:36 PM
72ford360
Oct 22, 2004 11:32 AM
