is it worth camming my 360
on
1. A good 2.5" exh system with header an a pair of flow through mufflers.
2. A good Ignition system, 3. The carb jetted and dialed into your engine,
4. with a cam, 5. Some head work of gasket matching light slag port cleanup on the port runners for intake & exh. 6.New under cut ss valves & valve springs with HD retainer & locks. 7. A good 3 angle valve job done on the heads.
And the cam you choose will be a contender.
Orich
Orich
on
Orich
Orich
IMO no.
The 360 has low compression and a sunken piston. You can't make a performance engine out of it. You can add the 4bbl and manifold and headers and you will notice a nice increase in power.
But imo, don't fool with the cam. If you are going to fool with it, convert it to a 390, 410 or 445.
The 351M suffers similar compression issues. The aftermarket cam for that engine with the stock compressin actually has a shorter duration, but higher lift than the stocker. For your 360 you would have to determine the specs for your cam, and find one with shorter duration and higher lift. That will also require new springs and probably new pushrods. While you're at it, valve seals. And maybe a valve job....
on
Wow, I am assuming it's a 4wd now you'll need to throw in a Dana 60 front axle to help and low gears to flip those 44's around to not break axles.
What you want to do is not a cheap fun hobby and take thousands of bucks to do it right. Until you break something or blow the motor..
Racing is a rich mans hobby & a poor mans dream.
My .02cents
Orich
On a 360, your money will be better spent on just doing the exhaust, intake, and 4V carb. I received an Eddy 2106 cam kit in a trade for a pitman arm and decided against camming the '70 due to the smaller displacement, low compression, etc. The kit will likely find its way into my 73 4x4 with a 390.
Gees for what you want it for I'd find a early 429/460 motor but your dreams of a some what mud truck with 44's.
My .02cents
Orich
My .02cents
Orich
