302 to 460
Old Oct 20, 2004 | 11:38 PM
73effie's Avatar
73effie
302 to 460
hi all. quick question: aside from the obvious(frame mounts, c-6 tranny, heavier coils), what would it take to swap a 302 to a 460 in a 73 ford pickup? any fabrication/welding? or is it basically a bolt-in deal?
appreciated
eddie-
Old Oct 21, 2004 | 09:59 AM
312's Avatar
312
its a bolt in if you have the right parts.
Old Oct 21, 2004 | 12:08 PM
73effie's Avatar
73effie
how about headers? doesnt seem like they will fit.
Old Oct 22, 2004 | 07:02 PM
bigblackbeast's Avatar
bigblackbeast
fenderwell exit headers seem to be what everyone is using,they are pricey but fit well ($350 to $450) you can get them from broncograveyard.com makes the job easier. or if money is an issue then exhaust manifolds from a 460 powered truck or van (like i am going to do until i can save for the headers) will work just fine .i hope this helps.
Old Oct 22, 2004 | 07:38 PM
73effie's Avatar
73effie
so standard headers wont fit to well?
Old Oct 23, 2004 | 08:14 AM
mark a.'s Avatar
mark a.
Hooker makes inside frame headers for them.
Old Oct 23, 2004 | 12:00 PM
73effie's Avatar
73effie
great, thanks alot.
Old Nov 3, 2004 | 04:28 AM
docholiday72tx's Avatar
docholiday72tx
I have a 73 F100 swb pick up. I put a 460 and c6 from a 83 model van in my truck. I used flow tech headers. They were just under $200. I've had them in there almost a year with no leaks. I did go to Hi Lo O'rielys and bought a starter for a 75 model full size car with a 460. That starter comes with a heat shield already on it. The headers that I have go between the engine and the frame rails. It's a tight fit, but it will work. In my truck, it started out as a 240 and 3 speed. I went to a 302 and c6, then a 390 with a 4 speed, then up to the 460 with c6. All of them were bolt in deals. If you decide to go through with the swap, let me know. I can give you a few pointers to make things easier and maybe a little cheaper for you.
Old Nov 3, 2004 | 04:41 PM
slappy's Avatar
slappy
If you are going to use the hooker super comp headers, you must also use the hooker super comp frame mounts, no others will work. They are a little spendy, but a clean install. I would like to know the part number of those flowtech headers. I thought hooker, l and l, and hedman were the only coices.
Old Nov 4, 2004 | 05:45 AM
docholiday72tx
Slappy, the flow tech header part number for a 73 to a 79 ford F100 through F350 with 2 wheel drive and a 429/460 is 12564 for the standard headers, and 32564 for ceramic coated headers. I found my reciept for them, and they actualy cost $170.00 for the standard headers.
Old Nov 4, 2004 | 11:48 AM
slappy's Avatar
slappy
Thanks docholiday but after reading my post I see that I didn't mention that I am 4wd.
Old Nov 4, 2004 | 03:07 PM
docholiday72tx
Hey Slappy, I bet if flowtech offers them for 2 wheel drive, they probably also offer them for 4 wheel drive. I also wonder what the actual difference in the 2 and 4 wheel drive headers is. It might be that the 2 wheel drive would interchange. It's an awfully tight fit and I doubt it, but you never know. If you want to find out for sure, I have the address, phone number, fax number, and email address.
Old Nov 4, 2004 | 05:12 PM
slappy's Avatar
slappy
I believe there is an issue with frame tower clearance as well as crossmember clearance on the 78/79 4wd. cross member shouldn't be a problem on 73-77 3/4 ton 4sp but the motor mounts are still an issue.
Old Nov 4, 2004 | 05:35 PM
mark a.'s Avatar
mark a.
Did you use the van 460 motor mounts ? If so did you have to do anything to the towers ?
Old Nov 4, 2004 | 09:48 PM
docholiday72tx
Mark, When I bought my 460 and c6, I gave 600 for the whole truck that they were in. The guy had bought a 1970 F100 with a 360 and c6 that were wore out. Then he bought the van which had low miles on a rebuild of the motor and tranny. He bought motor mounts and stands from a wrecking yard out of a 75 model. He put the 460 in the 70 model, then couldn't figure out what to do about the drive shaft and the exhaust. He got divorced, then broke, then discouraged and I ended up with a good deal. To answer your question, my mounts and stands did not come from the van, and the van stuff won't work as far as I know. Keep the questions coming, I like helping a fellow enthusiast.
