Bronco II Ford Bronco II
Cold Air Intake
Old Oct 27, 2004 | 05:34 AM
  #31
Hydrogen18's Avatar
Hydrogen18
vacuum sensor? I dont know why though, cant it just read that off the intake manifold?
I might give it a disconnect and see what happens.
Old Oct 27, 2004 | 03:11 PM
  #32
RomerB2's Avatar
RomerB2
The metal part went to the engine, don't know what it did but I took it off, the only thing I have connected to the airbox is what looks to be some sort of vacuum line, and it goes under the engine I believe, and the tubing to the TB.
Old Oct 27, 2004 | 07:19 PM
  #33
Ken00's Avatar
Ken00
The sensor in the airbox measures the air temperature, when it's cold the sensor open and vacuum flows to the valve down by the frame rail which divers the intake air flow from the normal air intake to the area by the exhaust manifold. This stops icing in the throttle body during cold weather. No reason to disconnect it but if you do plug the vacuum line at the engine.
Old Oct 27, 2004 | 08:22 PM
  #34
Hydrogen18's Avatar
Hydrogen18
so the sensor wont mind getting a crazy reading, the vacuum hose will just have a vacuum on it but be plugged. How should I plug it if I install a cold air intake from a 95 neon?
Given the place it ends up I figure it will get plenty of heat and I live in Mobile, Alabama.
Old Oct 27, 2004 | 08:33 PM
  #35
Ken00's Avatar
Ken00
A rubber cap on the port or a piece of hose with a golf tee in it.
Old Oct 28, 2004 | 12:51 AM
  #36
RomerB2's Avatar
RomerB2
Ducktape work?
Mackij3
1978 - 1996 Big Bronco
Mar 3, 2013 06:34 AM
dieselsmoker
6.4L Power Stroke Diesel
Jan 31, 2013 03:43 PM
mudlite
2004 - 2008 F150
24
Sep 20, 2008 07:19 PM
bigredford04
May 28, 2002 09:21 PM
proford460
May 16, 2002 11:12 AM
